Vehicle camera mounts at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Special Mounts and Applications
Old November 24th, 2008, 08:37 AM   #1
I would like to know how the wild life film shooters in Africa use the vehicle-mounted cams from inside of the vehicles. On what they mount the fluid head receiver bowl, which is a very sturdy. I would like to make such kind of thing to my vehicle as it will be easier for me to use the vehicle as movable hide (Run & Shoot). It's more useful for birds as the vehicle doesn't scare them away. (I'm not interested in suction/vacuum cup grips)
Somebody has got catalogue or even photographs of such system kindly post it.
Ashok
Ashok Mansur is offline   Reply With Quote
Old December 7th, 2008, 04:06 PM   #2
Images: 18
Well hello there, Ashok...........
Long time, no speak.
Didn't see your post hiding down there.
Of the three vehicles I've seen used for shooting African wildlife, all had been seriously modified to make a mobile shooting platform.
Two had the passenger doors removed and an additional platform bolted/ welded to the side of the vehicle to make an outrigger platform.
The downside of this arrangement was that this platform stuck out quite some way from the vehicle, putting it's occupent is serious danger in the event of a collision with something solid like a tree.
The third, and seemingly both the safest and more user friendly, had a large circular hole cut in the roof, the rear seats removed to make a standing platform and a circular turret ring fitted to the roof around the full circumference of the hole, allowing both the operator and the camera mounted on a pan/tilt head to be swung through 360 degrees (like those plane mounted machine gun systems.
Very effective but eye wateringingly expensive to do.
And, of course, each of the vehicles in question were extremely large 4WD's with shed loads of room for manouvre.
Going to a standard saloon car, I take it removing doors is out, and I can't see the "hole in roof" thing going down a bundle either.
Doesn't give you a shed load of options, though you may be prepared to be a bit more ruthless than I would with my car.
CS
Old February 2nd, 2009, 09:00 AM   #3
Thank you Chris,
I was really surprised how come you haven't responded, in-fact after a week stopped seeing this thread as no one responded to this. Can you give me the links wherein I can see the photos of the vehicles.
Ashok
Old February 6th, 2009, 07:24 PM   #4
Images: 18
Hi again..........
Missed you again, really think this section should be changed so it isn't so easy to "lose" posts.
Well, I've found this:
AAD SAFARI Landrover Special Vehicles and Safari Vehicles
but the photo's are useless.
Then there's:
Safari Vehicles Photos
and
Land Rover Safari Vehicles
and
our Safari vehicles, Landcruisers and Prados
None of them really give any detailed shots of the camera platforms per se, so guess you'll need to take it from here.
CS
Chris Soucy is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Special Mounts and Applications
