Air mobile! A challenge... at DVinfo.net
Go Back   DV Info Net > Most Recent Additions... > SPC - Single Person Crew
Who said "One is the Loneliest Number?" You'll never walk alone here.
Old July 7th, 2013, 10:59 AM   #1
OK, here's the challenge... working on one myself:
Adequate gear for lit sit-down 2-camera interviews and 1-2 nights stay with editing, to fit into two carry-on bags (or fewer).
I keep getting stuck on the tripods, unless I settle on my chincy photo tripod...
Putting one together today from what I have, I'll post back with results...
www.mcbob.tv
Kevin McRoberts is offline   Reply With Quote
Old July 7th, 2013, 01:59 PM   #2
Re: Air mobile! A challenge...
I bought a plastic travel case for golf clubs to hold my Sachtler DV10 tripod. I wrap the tripod in some bubble wrap to protect it. I can usually put a couple of light stands and some extension cords in itbas well, staying underr the 50 lb. limit for airlines. The case cost was about $75.
Michael Sims is offline   Reply With Quote
Old July 7th, 2013, 02:03 PM   #3
Just re-read your post and realized my reply was no help. Sorry. The carry-on bag limit really limits your choices.
Old July 10th, 2013, 11:32 PM   #4
I have been known to rent a tripod and light kit locally. While a rental house is usually a pain for that kind of thing, in the one location where I frequently encounter this problem, I have a relationship with a videographer who lets me rent his gear. Nothing electronic, just sticks, lights, and stands. Really lightens the load on the flight.
I have used cheapo tripods and light stands from Amazon, and had them shipped to my hotel (or to the client) to precede my arrival. However, you look like a phony, using a $5k camera on a $20 tripod. (After the gig, I abandon or donate the gear.) If you go this route, I can get two 500LED panels in a carryon suitcase, with enough room for a couple of extension cords, a clean shirt, and a variety of grip gear. I assume the other carryon is a Pelican 1510 or similar, with the camera and accouterments.
If you check luggage, I also do the golf bag thing, with the tripod in it and a couple of light stands. The only thing to be careful of here is that it can get over 50lbs fast.
Mike Watson is offline   Reply With Quote
Old July 11th, 2013, 07:39 AM   #5
You can always drop ship your gear to your location via Fedex or UPS for example.
I usually just drive the needed gear.
David W. Jones
www.joneshdfilms.com
Old July 15th, 2013, 05:49 PM   #6
OK, I think I have something. Wish I had a Pelican 1514 (or 2) but only have a photo backpack (Tamrac, model unknown) and standard rolling carry-on suitcase... of course benefit is it's easier to put longer gear diagonal in the suitcase.
BACKPACK
2 bodies (AF100, GH2)
ample batteries for 1 full day operation; small travel chargers
3 lenses (Panasonic 12-35, Leica Summilux-R 35, Sigma 50-150, Speedbooster)
12' XLR cable
ECM-44b wired lav
Azden SGM-PDII
Sony 7506's
Lowel Pro-Light
handful of clothespins
GoPro3 & clampod (why the heck not)
personal doodads (gum, phone charger, earbuds, etc)
SUITCASE
25' XLR cable
10' extension cable & triple tap
2x inline dimmers
4 small Lowel light stands
Matthews Mini Grip Kit
2 Pro-Lights
2 white photo umbrellas
diffusion, ND, CTB gels
3 5-in-1 reflectors
*2 Benro MeFOTO A0350 travel tripods
2 Manfrotto 701HDV heads
2 3lb leg weights
change of clothes, meds, n' stuff.
I'm electing to suck it up and check a tripod case containing a sturdy set of sticks, extra light stand, and a RIFA 55, but I'll have my base requirements met if that happens to get delayed or lost.
* the MeFOTO tripods are somewhat of an unknown quantity, bought 2 (why not). They're small and inexpensive, and seem to be relatively sturdy for their size, aluminum with borderline ridiculous 5-stage legs. They're only suitable for seated interviews, which luckily is exactly what this project is. The included ball head unscrews to a bare 3/8" stud, which suits the 701 heads just fine. The bottom of the extending column has a weight hook, and with enough weight it makes tripod movement while rolling viable (hence the leg weights). It's all a bit small for the AF100, even fully stripped down, so I'll likely use that for my static wide and operate the GH2 for closeup.
I get to do a "test run" with this setup locally on Wednesday, and hopefully it'll serve well over the next 2 months or so.
www.mcbob.tv
Old July 15th, 2013, 06:22 PM   #7
If you elect to check the bags, make sure you tell the airline that you're traveling as a production company and you would like the "media rate" for your checked bags. I have checked 75lb+ pelican 1650 cases and tuffpak tripod tubes for $50 each flat fee. I'm sick of scratching my head over carry on only gear and the media rates seem reasonable enough for the client to pay for it without issue. I know that Delta, Suncountry and a few others do this. All they require is a printed "credential" of some sort showing your affiliation with a production company.
I made my own...
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply
  You are here: DV Info Net > Most Recent Additions... > SPC - Single Person Crew
