PIX 240 Reviews? - Page 2 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sound Devices PIX series Recorders
Old January 5th, 2012, 01:33 PM   #16
Re: PIX 240 Reviews?
That info is on the main website but the approved devices post in the forum has not been updated yet.
http://www.LandYachtMedia.com
Old January 8th, 2012, 09:14 AM   #17
Originally Posted by Chris Dickinson View Post
I believe the 470 is discontinued now, so Sound Devices had better get busy testing some more SSDs! I bought tow Sandisks and had a weird moment with one. For each SSD I have a caddy, and SSD1 had a real issue - when I put it into record, it tried, but then stopped and my PIX came up with a warning "Media is too slow"... But just before going to sleep I thought I would try it one more time - you know, just in case... And it worked! Tested all compression rates and it was fine..!
Weird...
Chris
OK - so I tested it AGAIN, and it was once again SLOW! So I had to get it replaced for a new one, which works just fine - so lesson to TEST SSDs before you do a job, just because Sound Devices approves the SSDs it doesn't mean that the SSD is actually gonna work...I just didn't expect a SSD to be faulty...
Chris
Chris D
www.chrisd.tv
Chris Dickinson is offline   Reply With Quote
Old January 8th, 2012, 11:24 PM   #18
Curious - are any of you using CF cards with your Pix units? That was my plan as they are lighter and convenient.
Josh Dahlberg is offline   Reply With Quote
Old January 9th, 2012, 09:24 AM   #19
Yes I've got Sandisk Extreme 60MB/s CFs - even though Sound Devices don't have them on the approved list, they seem to work fine. I've gone for the SSDs though because they are cheaper - a 120GB SSD cost just a little more than a 32GB 60MB/s CF card... And I can also transfer the data via firewire from the pix Caddy at a faster speed than if I was using a CF cards and USB card reader... But CF cards make for a decent second option.
Chris
Chris D
www.chrisd.tv
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sound Devices PIX series Recorders
