FS5 does not detect AC adapter preventing me from firmware update at DVinfo.net
Sony XDCAM PXW-FS7 / FS5
Old July 27th, 2017, 01:31 AM   #1
For some reason my FS5 doesn't detect or charge from the ac adapter port. I've tried several ac adapters... I normally don't care because I'm running off battery 99.9% of the time. But the fact that it's not detecting the AC plus is preventing me from having the ability to upgrade to firmware 4.0... Are you all having any problems similar? And is there a way to get around the Need of the AC needed for the update?
Ty Turner is offline   Reply With Quote
Old July 27th, 2017, 03:02 AM   #2
Re: FS5 does not detect AC adapter preventing me from firmware update
May be too obvious form my side but:
Did you switch from 'charge' to 'dc out?'
Gildo Houtekamer is offline   Reply With Quote
Old July 27th, 2017, 06:10 AM   #3
...and make sure there is no battery on the camera... I think from memory? Also make sure you remove all cards from the camera to be safe.
Chris Young
CYV Productions
Sydney
Old July 27th, 2017, 04:30 PM   #4
yeah I've tried that
Old July 27th, 2017, 04:31 PM   #5
Chris Young
CYV Productions
Sydney
still no luck :(
Old July 28th, 2017, 12:30 AM   #6
Haven't been able to confirm this yet but check this out. maybe best to hold off till this situation is clarified.
HD Warrior » Blog Archiv » Meanwhile back at Sony…FS5 firmware V4 has been pulled with no explanation.
Chris Young
CYV Productions
Sydney
Old August 3rd, 2017, 04:45 PM   #7
So... any issues with the new firmware or is it alright to go ahead and do it?
Cheers
Alfred Okocha is offline   Reply With Quote
Old August 3rd, 2017, 11:26 PM   #8
Originally Posted by Ty Turner View Post
still no luck :(
Just had a thought. Are you 100% sure you are using the USB cable that was supplied with the camera. I have seen a couple of cases where another USB cable was used and the update wouldn't proceed. I notice with the FS5 upgrade instructions they don't specify that you MUST use the supplied USB cable. With a number of the other Sony cameras they specify to use the USB cable supplied with the camera. Sony goes on to say that
"Update functionality is not guaranteed with any other USB cable."
As I say just a thought. See below the warning from an X70 uograde.
Chris Young
CYV Productions
Sydney
FS5 does not detect AC adapter preventing me from firmware update-usb-warning.jpg
