FS7 handgrip Retrofit to ARRI Stdrd available here at DVinfo.net
Sony XDCAM PXW-FS7 / FS5
Old March 30th, 2016, 03:41 PM   #1
Hello,
I engineered a way to modify the FS7 grip into an ARRI Standard rosette config.
Two choices,
1. M6 stainless steel rosette with internal threaded socket
2. Male ratcheting M6 stud. Video below shows attachment.
I've been doing them for a couple weeks now, they are already out there and shooters really like the result - it's a silver bullet fix.
They are in stock and ready to go. Email for pricing - it's very fair.
I suggest people send me their grip and arm for detaching and retrofit.
USPS roundtrip takes usually 5 days ALL IN , including the retrofit itself.
DIY is available - it's an easy assembly BUT the Sony screws that connect the arm to the grip strip very easily - I've modified 8 grips now and found the factory uses varying amounts of epoxy on threads. I run a dedicated camera only machine shop and remove them safely/correctly. This is preferred. But it's your decision. If you strip the screws I can still remove them with tools but I charge extra for that.
The entire mod is footprint free so you can return to factory at any time.
A couple people also asked for threaded rosettes on the Sony arm - that's easily done as well.
I'm at info@shootingmachine.net
Caleb Crosby, soc
ShootingMachine.net
https://www.facebook.com/shootingmac...homepage_panel
FS7 handgrip Retrofit to ARRI Stdrd available here-img_5014.jpg   FS7 handgrip Retrofit to ARRI Stdrd available here-img_5295.jpg
Caleb Crosby is offline   Reply With Quote
Old March 30th, 2016, 04:11 PM   #2
Re: FS7 handgrip Retrofit to ARRI Stdrd available here
I call it the Crony since it's a companion piece to the FS7.
Below clip shows the unique way it works.
cheers
Caleb Crosby, soc
ShootingMachine.net
