.MXF to .MOV? at DVinfo.net
Sony XDCAM PXW-FS7 / FS5
Old January 26th, 2016, 12:28 PM   #1
.MXF to .MOV?
FS5 in XAVC-HD produces MXF clips. I can edit fine with these in Premiere Pro.
In the Finder, I can't "preview" (see a thumbnail or even play a few seconds) of these clips.
With the FS-100 (my old camera) we were using ClipWrap to re-wrap MXF files as MOVs, there was no data loss (just a re-wrap), and they were more versatile. ClipWrap won't work with the new MXF files. Anything that can help fix this?
Mike Watson is offline   Reply With Quote
Old January 26th, 2016, 12:40 PM   #2
Re: .MXF to .MOV?
Have you looked at Catalyst Browse as a viewing utility?
Dave Sperling is offline   Reply With Quote
Old January 26th, 2016, 01:25 PM   #3
Re: .MXF to .MOV?
I've found that this software "kind-of" works to view the files. There doesn't seem to be a good way at this time outside of Sony Catalyst.
http://www.calibratedsoftware.com/pr...eV1/QAVCLG.php
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply With Quote
Old January 26th, 2016, 02:22 PM   #4
Vortex Media
Re: .MXF to .MOV?
As Dave says, get Catalyst Browse. It's free and does a lot more than just serve as a viewer. Problem solved.
Frankly I can't see how someone could own one of the Sony cameras and not use Catalyst Browse.
Old January 26th, 2016, 03:07 PM   #5
Re: .MXF to .MOV?
+1 on Catalyst Browse - you can't beat free.
For what it's worth, EditReady - the $49 successor to ClipWrap - will also play/convert these files (in addition to offering several other features).
David Dixon is offline   Reply With Quote
Old January 26th, 2016, 05:49 PM   #6
Re: .MXF to .MOV?
I was under the impression you had to transcode all FS5 files if you want to use them with Premiere Pro. Can I just confirm XAVC-HD files from a FS5 can be edited by Premiere CC and CS6 without transcoding?
Nigel Davey is offline   Reply With Quote
Old January 26th, 2016, 09:05 PM   #7
Re: .MXF to .MOV?
Yep. No transcode. Edits fine.
