Sony FS5 Firmware 1.1 Update Released at DVinfo.net
Sony XDCAM PXW-FS7 / FS5
Old December 22nd, 2015, 09:04 AM   #1
It looks like the FS5 V 1.1 firmware is now ready…
Sony?s Christmas surprise – FS5 firmware version 1.1 available for download
Old December 22nd, 2015, 01:03 PM   #2
Re: Sony FS5 Firmware 1.1 Update Released
Well, this will make things easier and sooner than we all expected to boot. The 4K face detection is a nice bonus as well. Seems you still can't use an external monitor with face detection at the same time though. Putting a SmallHD 501 on the camera with overlays turned on has almost made me leave the included LCD at home. It will be interesting to see how well the face detection works...
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply With Quote
Old December 22nd, 2015, 02:16 PM   #3
how do you turn on overlays? I can't for the life of me find this feature. Thanks!
Josh Swan is offline   Reply With Quote
Old December 22nd, 2015, 03:29 PM   #4
Sponsor: Westside AV
Oops we have two of these posts going!
The update went very smoothly. About 4 minutes on a MBP.
Just follow directions precisely.
Use AC power, I used AC on UPS just in case of power outage, we are having a storm here. I also removed the battery.
Remove your SD cards, this is in the instructions.
Also if you did any customization, make sure you save the profile to an SD card before updating as everything is reset including time/date. I had a bunch of PPs I was playing with, and they restored fine from the SD card, I only reset my region and time after the update. The cam profile even saves your custom button assignments/iso settings etc, and that worked fine as well after restoring.
Merry Xmas everyone.
Old December 22nd, 2015, 05:42 PM   #5
In the "Display Set" menu. The term for it is "Display Output." See page 135: http://www.vocas.nl/webfm_send/1239
Old December 24th, 2015, 02:15 AM   #6
There is a report (posted as a comment on XDCAM User today) that FS5 firmware V1.1 results in the cam loosing date and time data, even after only a few minutes of being switched off. Reverts to default, even with battery still attached apparently.
Anyone else seeing this with this new firmware? Any other strange behaviour?
Note: Experience has taught me to hold back on all firmware updates for a while to see what bugs might emerge...which us why my FS5 is still on V1.0!!!
Old December 24th, 2015, 03:39 AM   #7
No problem here. I just checked the camera...did the firmware update yesterday.
Gildo Houtekamer is offline   Reply With Quote
Old December 24th, 2015, 04:27 AM   #8
I also decided to wait, but I actually had it drop the date once an hour or so after I set it for the first time... hasn't happened again in the couple weeks I have owed it
Ray Lee is offline   Reply With Quote
Old January 12th, 2016, 07:56 PM   #9
After updating the Sony PXW-FS5 - The ISO/GAIN button next to white balance and shutter in manual mode will not allow me to adjust gain or ISO when pressed. I have a choice between auto and whatever it was previously set to. I can manually adjust gain / iso by pressing function 5 on grip zoom then navigating joystick. Is this something Sony needs to fix? White balance and shutter works but not the iso / gain. What if I do not use hand grip then do I need to go into menu and change gain / iso? I don't thing so. Camera will be returned if this is the nature of the beast. Is anyone else having this issue?
+ Face detection set to on disables joystick after fn5 is pressed on hand grip zoom. Is anyone having this problem? So close to returning this camera.
Robert Boni is offline   Reply
