From Cine EI to Custom Mode at DVinfo.net
Sony XDCAM PXW-FS7 / FS5
Old February 8th, 2015, 07:34 AM   #1
Shooting in Cine EI, Color Space S-Gamut3.Cine/Slog3, XAVC-I 3840x2160 25P
When I set the Shooting Mode back to Custom the Color Space does not change, the Viewfinder stays on S-log3.
Even when I select another preset like High Saturation, nothing changes, it stays on S-log3.
When I reset the camera or load the previous settings from the SD Card then its OK again.
It this a bug or do I missing something?
Firmware: 1.10
Geert Geerits
Geert Geerits is offline   Reply With Quote
Old February 9th, 2015, 06:21 AM   #2
Vortex Media
Re: From Cine EI to Custom Mode
You're mixing up the concepts of Gamma and Color Space.
If you don't want to use S-LOG3 when you come out of Cine EI, then you have to change the Gamma setting in the paint menus to something else. It sounds like you are changing the matrix settings and expecting those to also change the gamma. It doesn't work that way in the Custom Shooting mode.
Doug Jensen's Sony PXW-FS7 Master Class
Doug
Old February 9th, 2015, 09:54 AM   #3
Thanks Doug, this was the solution.
Geert Geerits
