#16 | |
Re: Sony F3 with hyperdeck shuttle questions
Using the PIX-240, F3, and SmallHD DP6 together on a 96wh battery I get 2.5-3hrs of runtime. That suggests a total consumption of everything in the 30-40wh range.
http://www.LandYachtMedia.com |
#17 |
Ah yes I was thinking spin-up drives. I will correct my post before someone takes it as gospel.
Most SSD's are .5w when not doing anything but once in operation they can range from 2w up to 6w depending on the manufacturer and specific model. Still rather negligible as you suggest. |
#18 | |
Dennis thanks for the link I just ordered the cable just waiting on the rest I will post pictures later |
#19 |
Great and if you don't have a v-mount plate you can also buy one from him as well which has a d-tap port on the side. But you would need to install/solder your own connector on the end to power your camera and also make note of the proper polarity.
Sorry I should have put that link up earlier as well. If you buy the hyperdeck shuttle plate for $100 and a rail mount from berkley it will let you mount the plate vertically on your rails and then you can mount your deck on one side and the power plate on the other. Add a d-tap splitter and you've got enough room to grow and power the world with. |
#20 | |
Check first! |
#21 |
Here is my F3 rig with hyperdeck and power solution:
#22 |
Dennis this looks very nice.I received the power cable from that ebay seller just waiting on the rest of equipment am exited to test out and will put pictures as soon as I have everything
#23 |
Hi Rudy, sounds great that you received the d-tap to 2.5mm jack power cable. Sorry I will repeat it again, but please make sure you check the polarity of that power cable first before using.
For example, on my v-mount plate I actually had to put the d-tap cable on "backwards" in order to get the proper polarity out of the 2.5mm jack. I plan to open up the d-tap plastic housing and reverse the polarity when I get a moment. |
#24 |
Thanks Dennis I will check it out
#25 |
Okay today I received my Hyperdeck Shuttle 2,Crucial m4 512GB SSD,Pro BNC Female to DIN,Comphrehnsive cables adapter BNC/M to BNC and also a Shoe plate to mount the hyperdeck till I get something better to mount .
I will put some pictures in a couple off days |
#26 |
The seller of the d-tap to 2.5mm power cable said he can configure the wires any way you want, or you can open the connector and flip things around if needed.
Sure post some pics once you get it all together! |
#27 |
Dennis I got a question I connected the Hyperdeck Shuttle 2 on my Sony F3 SDI out because that was the only way I got it to trigger the recorder is this normal ? Are you able to get the recorder to work on either SDI A or B ?
#28 |
Yes I managed to get the recorder to work (see video and trigger) through both the monitor SDI out port, as well as the SDI-A out.
I do recall having some issues at first with SDI-A, mainly you have to go in the menu of the F3 and play around with the output options. As for triggering I'd have to check what mode I used that worked for me. CAUTION: one silly thing that took me hours to figure out is that when you use the USB cable and HyperDeck utility to change the settings of the deck, when you first power that deck up again make sure you press the STOP button on it. The default after powering up, or running an update is in PLAYBACK mode so it will NEVER trigger in that mode. This wasn't even documented anywhere but it became a little more obvious once I hooked up a monitor to the HDMI output port on the deck for testing. Once you get through the pain points, its smooth sailing from there. |
#29 |
Dennis the power cable worked just fine how I received it so lucky me...for the SDI A or the SDI B no luck but it works perfect on the SDI OUT so I will try to figure it out on the SDI A.
Picture is coming soon |
#30 |
In your menu is your "dual-link & gamma" option set to 1.5G YPbPr422 & Video ?
