F3 Before and After at DVinfo.net
Sony XDCAM PMW-F3 CineAlta
Old December 12th, 2012, 10:49 AM   #1
F3 Before and After
Here is some footage showing footage shot in low light that has had heavy SFX applied to it. This was shot with a Zeiss CP lens using S-Log and recorded 10bit to a PIX240. The FX were done in After Effects. The YouTube compression isn't as good as the link showing the process.
The step by step story can be seen here:
Kmotion Media :: Blog
Gregory De Tennis is offline   Reply With Quote
Old December 13th, 2012, 05:12 PM   #2
Re: F3 Before and After
What did you find the advantage was of using the F3 for this project, over say a DSLR, or even a camera with a smaller sized sensor?
Dennis Hingsberg is offline   Reply With Quote
Old December 17th, 2012, 07:45 AM   #3
I actually OWN the F3. I also LOVE the S-Log. So why rent when you own?
Old December 17th, 2012, 09:17 AM   #4
From applying a lot of effects like this one to DSLR footage, I can say that the DSLR footage falls apart rather quickly if you push it around a bit. Get a lot of H264 chunking that can build up rather quickly if you dont pay attention to your details. Keying works, but with 4:2:2 it is a LOT easier to get a read on the color you want to pick out when dropping a chroma key on it. You can always resort to manually masking but thats usually no fun and time consuming.
Got the chance to do some shot correction on some shots done in 4:2:2 recently (removing tripod bags from ledges, mics from within moving scenes, etc) and it held up rather well, but for basic stuff like that DSLR should be about the same.
Automotive Multimedia
Justin Molush is offline   Reply
