Project F3 finished at DVinfo.net
Sony XDCAM PMW-F3 CineAlta
Old August 13th, 2011, 11:10 AM   #1
Project F3 finished
Thats what my finished Rig looks like now. It works really good with the hoodloupe. For me, it makes an external VF obsolete. I added an external Monitor for the Director too. The Battery for it works as a counterweight.
Matthias Sachal is offline   Reply With Quote
Old August 13th, 2011, 11:38 AM   #2
Re: Project F3 finished
Looks a bit like sticking a Ferrari engine into an old Ford Escort ;) Can the 501 support all that weight?
Old August 13th, 2011, 06:17 PM   #3
Macgyver would be proud!
John Cummings is offline   Reply With Quote
Old August 13th, 2011, 10:58 PM   #4
looks badass except for the tripod
Tom Bostick is offline   Reply With Quote
Old August 14th, 2011, 10:46 AM   #5
looks like it will be front heavy, just a job with the shoulder pad in the same place as your set-up and it was painful.
Chong Pak is offline   Reply With Quote
Old January 11th, 2012, 04:03 PM   #6
I now improved it in some aspects. I added a V-Mount Plate by Bebop. Also a new Swing-Away Mattebox which just arrived today. Its the MB-900 by Cinecity. It is big as hell as its a wide-angle Mattebox, which is a little letdown for me, since I wanted a smaller one after my Geardear One. But the Swing-Away feature makes up for it.
http://dl.dropbox.com/u/18368412/F3.jpg
Old January 11th, 2012, 04:13 PM   #7
thats a slick rig man!
Old January 12th, 2012, 08:26 AM   #8
Be careful you don't bend your flip out viewfinder hinge. My door doesn't completely close anymore after I tried the same method. It is very very weak.
Old January 13th, 2012, 01:05 PM   #9
Looks cool. However, you could use a better tripod, the tripod looks like it couldn't support all that weight and do fluid movement. I would also hate to have to put that on my shoulder for any amount of time. I sure hope you have a focus puller!
Gregory De Tennis is offline   Reply With Quote
Old January 21st, 2012, 09:36 AM   #10
You forgot the fuzzy dice.
Jim Michael is offline   Reply
