My First S-Log Tests. at DVinfo.net
Sony XDCAM PMW-F3 CineAlta
Old August 13th, 2011, 12:52 AM   #1
Hi There,
I just wanted to share my first tests shooting in S-Log with the F3. Recorded onto a KiPro Mini in ProRes (HQ) but looking forward to shoot in 444 when my Gemini arrives.
I love my S-LOG. | _mxr blog
Applied the LUT and did a quick colorgrade in FCP.
Christoph Tilley is offline   Reply With Quote
Old August 13th, 2011, 02:20 AM   #2
Re: My First S-Log Tests.
I think I can understand one of the major benefits of the s-log. Does it make the black lines look more defined? Obviously it must also lead to a clearer picture.
In order to work with raw data like 4:2:2 or 4:4:4 in Final Cut, what sort of Apple computer do you use?
Peter G. Johnson is offline   Reply With Quote
Old August 13th, 2011, 02:27 PM   #3
S-Log gives you about 3-4 stops more dynamic range. This results in less clipping highlights and less clipping blacks.
I am on a 12-core MacPro filled with 32gigs of RAM. This is what makes After Effects fly.
Old August 13th, 2011, 02:59 PM   #4
Not sure S-Log gives 3-4 stops. More like 1.5 to 2.
Given that a standard F3 is 11.2 stops, another 3-4 stops would take it into some incredible 14-15 stop territory that even film can't rival.
4 stops is 16x the dynamic range of a standard F3, hmm, I'd love to believe my cameras were capable of that but I can't. I've measured 12.5 to 13 stops with S-Log.
Old August 13th, 2011, 02:59 PM   #5
What was the light like when you shot this? Looks overcast or in shade already. Not a great need for Slog in that situation if I'm right.
Old August 13th, 2011, 05:42 PM   #6
@Leonard: It was a sunny day but at dusk time already. I think that shooting in S-Log can give you better results regardless of the situation or setting. You have to grade it though.
@Alister: Yeah, I think you're right. I might be mistaken. 3-4 stops would be just too incredible. But even 2 stops additional dynamic range is quite impressive in my eyes.
Just came home from filming similar situations at nighttime with full moon also in S-Log. Cant't wait to evaluate the shots. Will post here as soon I have something together.
