F3 Scene Files from AbelCine at DVinfo.net
Sony XDCAM PMW-F3 CineAlta
Old May 23rd, 2011, 10:45 PM   #1
You guys at AbelCine are amazing...
Thank you so much for your contribution!
F3 Scene Files from AbelCine | CineTechnica
Henry Epstein is offline   Reply With Quote
Old May 26th, 2011, 06:16 AM   #2
Telecam Films
Re: F3 Scene Files from AbelCine
Has anyone succeeded in installing those? I don't think the F3 can load more than one profile at a time so, I think Andy needs to repost each profile in a separate file. Thanks to him for all his great work on this.
Thierry.
Thierry Humeau, DoP
Télécam Films
www.telecamfilms.com
Thierry Humeau is offline   Reply With Quote
Old May 26th, 2011, 06:39 AM   #3
you have to go to camera data then recall, it will load all the scene files. but beware, it also resets all your settings.
Ian Planchon is offline   Reply With Quote
Old May 26th, 2011, 10:15 AM   #4
Yea, its not just a scene file but a full camera setup file.
It overwrites everything including button programming, gain settings, etc.
http://www.LandYachtMedia.com
Old May 26th, 2011, 10:56 AM   #5
F3 allows you to save/load camera data files. Saving/loading camera data files will also save/load ALL picture profiles.
F3 also allows you to save/load picture profiles one by one.
Someone should load the Abel data file and then save each PP as a separate file. This will allow us to try them without reconfiguring the whole camera, just to check out a PP.
Aaron Newsome is offline   Reply With Quote
Old May 26th, 2011, 10:27 PM   #6
Telecam Films
Thanks for confirming this. I was indeed afraid to loose all my camera settings by loading the profiles using the setup file menu. So, yes, it would be great if Andy could post each of those settings as a separate profile.
Best,
Thierry.
Thierry Humeau, DoP
Télécam Films
Old May 28th, 2011, 11:59 AM   #7
Great test. Thanks Andy!
Chuck Fishbein is offline   Reply With Quote
Old May 28th, 2011, 12:35 PM   #8
I have saved out the Picture Profiles individually and put them into the attached archive. It appears as if PP 7 is a duplicate of the Other HISAT PP. I believe it was intended to be JR45CIN2, a much more useful profile.
If someone downloads this would they verify that the profiles have been saved out correctly.
Thank you Andy and thank you Abel Cine Tech for sharing these profiles. We appreciate that a lot of expensive gear and talented professionals were used in the creation of these files.
Old May 29th, 2011, 10:44 AM   #9
Sponsor: Abel CineTech
Wow, thanks Andrew! When I realized the problem I was going to do that myself. So if it's alright with you I'll post these files on the blog. Also I put JR45CIN2 back up next week. Sorry for the initial confusion, and thank you for figuring it out.
Andy Shipsides -Camera Technology Specialist
AbelCineTech, New York - Visit our Blog - http://blog.abelcine.com
Andy Shipsides is offline   Reply With Quote
Old May 29th, 2011, 11:03 AM   #10
I updated the blog with the files. Thanks again Andrew.
Old May 29th, 2011, 01:49 PM   #11
Not a problem Andy. Thank you for sharing your hard earned knowledge and considerable access to Able Cine Tech's (expensive) gear that allowed you to create these profiles.
Please use them on your blog. I was only trying to expedite things.
Andrew Stone is offline   Reply
