RED PRO 18-85mm (BT) with F3 - Page 3 at DVinfo.net
Sony XDCAM PMW-F3 CineAlta
Old June 5th, 2011, 03:50 PM   #31
Re: RED PRO 18-85mm (BT) with F3
Originally Posted by William Graydon View Post
Do you by any chance have an update? Thanks!
Yes the Nikon reverse gear works fine, but the extra gear is very very close to some of my largers lenses like the 80-200 and 80-400. I'm going to use it because I don't want to relearn focus direction if I get some PL's down the track. If I'm using a FP, it doesn't matter, but for my own stuff, I don't want to be switching directions. I'll probably look around for a more dedicated reverses follow focus.
Peter Corbett
Powerhouse Productions www.php.com.au
Peter Corbett is offline   Reply With Quote
Old June 7th, 2011, 04:53 PM   #32
Originally Posted by Ned Soltz View Post
As I ponder whether I can - or should- buy the F3, the Red Pro BT zoom is also a consideration.
I cannot speak from shooting with the lens. What I think is worth considering is that it is a very heavy lens-- about 10 pounds-- and would require support. Optitek makes support ring for it for $345 and you will also need a heavy-duty bridge plate for your rails, which could run $500. The Duclos support is $325 and they sell a heavy duty bridge for $525. I do not know whether their $275 bridge plate would support the lens. So that $6K lens is now closer to $7K. That's still a considerable savings over a new lens.
You certainly can't beat the value in a PL-mount zoom lens.
Ned Soltz
This lens follows no industry standards however. Most follow focuses dont work with it, because the focus ring is ALLLLLLL the way at the nose, and its so wide that the basic industry standard follow focus( ARRI FF4) does not fit under it. You would have to use an Oconnor.
Its VERY quirky ergonomically, but optically quite nice.
Director of Photography - www.timurcivan.com
Sony F3, Cooke lenses, sunny disposition.
Timur Civan is offline   Reply With Quote
Old June 7th, 2011, 07:33 PM   #33
Peter, Thank you for the update. Are you using Zeiss ZF's with the FF now? If so which ones? and is it necessary to use the reverse gear with them? Just trying to clarify. Thanks again!
William Graydon is offline   Reply With Quote
Old June 8th, 2011, 01:01 AM   #34
No I'm just using Nikons. I have the Tokina 11-16, Nikon 28mm, 50mm 1.4, 28-70mm 2.8, 105mm 2.5, 80-200mm, and 80-400mm.
Peter Corbett
Old June 9th, 2011, 10:03 AM   #35
A conversation has started on CML comparing Leica R's to Zeiss ZF's any thoughts on this?
Also, is there any adapter yet for the leica to f3 pl mount? besides the leics r ->nikon -> pl mount route.
Edit*- Does anyone know when this will come out and how much it will cost? http://www.pstechnik.de/downloads/11..._IMS-F3_en.pdf
Seems like the only place to purchase Leica R's is on ebay any other spots?
