F3 require circular polarizer? at DVinfo.net
Sony XDCAM PMW-F3 CineAlta
Old March 31st, 2011, 02:33 AM   #1
Do you need a circular polarizer on this Cam?
Old March 31st, 2011, 08:06 AM   #2
Re: F3 require circular polarizer?
No there is ND built in. Slide position 1=1/8
Slide position 2=1/64
Iam not a fan of using Circ Pol to reduce light. I find they tend to color shift skin tones. But I do love a polarizer for landscape work.
Dennis Dillon is offline   Reply With Quote
Old March 31st, 2011, 08:47 AM   #3
I'm not talking about equating a polarizer with ND, I understand the difference. Wondering if this camera requires a circular rather than a standard polarizer like some other cameras - the EX-1 for example.
Old March 31st, 2011, 09:44 AM   #4
Leonard,
Sorry, I had that circular ND thing in my head. Not sure by what you mean by "requires".? I believe any camera would benefit from a circular polarizer. It gives more choices on your angle of subject. I have always used a matt box with a rotating frame.
Old March 31st, 2011, 01:19 PM   #5
There are regular non-circular polarizers and i can get a good 4x4 used locally cheap - And there are "circular polarizers" that are needed for some kinds of cameras depending on the chip type and the method of doing auto-exposure. I would need to buy new. My question could also have been phrased - can I use a standard pola.
Sorry, Perhaps that would have been clearer.
Old March 31st, 2011, 02:38 PM   #6
Circular polas are for cameras that meter or have AF sensors behind the mirror (SLRs)
No such thing on this cam. Standard cine linear polas will work fine. I'm using my 138.
My Work: nateweaver.net
Old March 31st, 2011, 03:05 PM   #7
"Circular polas are for cameras that meter or have AF sensors behind the mirror (SLRs)"
Not limited to those situations. EX-1's need a circular polarizer .
However if you're using one that sounds good enough for me. Thanks Nate.
Old April 1st, 2011, 05:49 AM   #8
Once I have mine and work out the lens adapter I'll be able to check it out. I've got both types.
I am interested to see if there is any color shift with a LIN like there is on the EX1.
http://www.LandYachtMedia.com
Old April 1st, 2011, 06:05 AM   #9
Even though we don't meter through the F3 camera, I do check the brightness level indicator and histogram against my exposure, and if light reaching these two indicators is compromised by a linear polarizer in the same way it compromise an auto meter system, then in theory the readings of the level indicators and historgram are compromised too. Please correct me if I'm wrong, but I've been using a circular polarizer even though it's less effective and more expensive for the reasons above.
Also get the thinnest pola you can find. B&W makes a good one.
Brian Lai is offline   Reply With Quote
Old April 1st, 2011, 11:16 AM   #10
It's not compromised in the same way. An SLR has light meters and AF sensors in half-silvered areas behind the mirror. Linear polas mess how light reaches those sensors, in conjunction with the mirror. Completely different system.
In the F3, the exposure meters are based off the entire video image created from the sensor.
Old April 1st, 2011, 12:55 PM   #11
I asked this because unexpected issues can affect polarization
On the Ex-1 you get unexpected color shifts from linear polas that probably have to do with the beam splitter. But obviously not all 3 chip cameras needed a circular polarizer.
http://www.dvinfo.net/forum/sony-xdc...olarizers.html
So I'm looking for hands on observations, not theoretical stuff that may or may not be relevant. Nate said he is using a linear. That was useful information.
Nate - Do you mean a 138mm pola - what brand ?
Old April 1st, 2011, 01:00 PM   #12
I am guessing it won't be a problem on the F3 since there is no prizm setup. I will be testing it as soon as I get a lens adapter.
The F3 camera body arrived today.
Old April 1st, 2011, 01:25 PM   #13
Lenny,
I've used my F3 with both Tiffen and Formatt linear and circular polarizers and both without issue.
I have all of my filters in both 4x4 and series 9
Chuck Fishbein is offline   Reply With Quote
Old April 2nd, 2011, 04:08 AM   #14
It's been a few years since I've seen this one come up but it never ceases to confuse people. Hopefully everyone reading this understands at this point that circular polas have nothing to do with either the shape or the rotation of the actual filter.
I myself use a Schneider True-Pol 138. It's linear. I've never in my entire career needed to use a circular pola. Not to say there aren't a few cameras out there that require it; I just haven't used those, I guess.
Charles Papert
www.charlespapert.com
Old April 2nd, 2011, 11:08 AM   #15
I believe that is well understood her Charles, yet, in recent years, several video cameras and certainly many DSLR cameras have required circular polarizers to function properly. These cameras used some form of polarization in their metering system and I believe in some cases, auto focus systems. In some cameras it was obvious, like the viewfinder going dark or looking a bit posterized, other times, it shifted the color.
I think either my Z1 or PD-150 suffered from this.
