Run/Stop? at DVinfo.net
Sony XDCAM PMW-F3 CineAlta
Old March 28th, 2011, 02:23 AM   #1
Run/Stop?
Does anyone know if the 8-pin remote can take a basic run/stop button? There isn't a lanc or Fuji port hidden somewhere is there?
www.davidwilliams.com.au
David C. Williams is offline   Reply With Quote
Old March 28th, 2011, 09:04 AM   #2
Re: Run/Stop?
Dear David,
According to my research, the answer is no.
However, for a definitive answer, I would check with Sony.
Dan Keaton
Augusta Georgia
Old March 29th, 2011, 10:29 AM   #3
Re: Run/Stop?
Dan are you sure? That remote port looks exactly every remote port I've used for every sony camera I've used (f900, ex3, pdw700 etc) which can take an rmb-150 which does include a start stop button for recording on board. But maybe I misread? David do you just mean a single button that only stops and starts? Not actually using a remotepaint box to stop and start the cam? Does someone actually make a start stop button to sony 8 pin?
NIck
I have a dream that one day canon will release a 35mm ef to xl adapter and I'll have iris control and a 35mm dof of all my ef lenses, and it will be awesome...
Nick Hiltgen is offline   Reply With Quote
Old March 29th, 2011, 10:54 AM   #4
Re: Run/Stop?
Dear Nick,
I stand corrected.
The pin-out of the Sony F3 appears to indicate that a cable could be built to start and stop the camera.
Our next challenge is to determine what connector to use.
Dan Keaton
Augusta Georgia
Old March 29th, 2011, 03:49 PM   #5
Re: Run/Stop?
I am looking to make a run/stop cable for a BFD receiver. I have the pinouts thanks to Nate, but same as Dan, stumped by the plug :D
Old March 29th, 2011, 08:28 PM   #6
Re: Run/Stop?
I thought those were Hirose plugs?
My Work: nateweaver.net
Old March 29th, 2011, 09:23 PM   #7
Re: Run/Stop?
I thought they were hirose as well.
Aaron Newsome is offline   Reply With Quote
Old March 30th, 2011, 04:47 AM   #8
Re: Run/Stop?
Dear Friends,
They may be.
We have an F3 in our Lab and I will have our team check it out.
Dan Keaton
Augusta Georgia
Old March 30th, 2011, 05:25 AM   #9
Re: Run/Stop?
Pretty sure it's a Tajimi. It's identical to my Fujinon 8-pin controller, but the next size down.
Old March 30th, 2011, 07:23 AM   #10
Re: Run/Stop?
Dear David,
Are you referring to the standard Lens to Camera connector?
If so, those are Hirose.
Dan Keaton
Augusta Georgia
Old March 30th, 2011, 03:49 PM   #11
Re: Run/Stop?
Just to be clear, aren't we talking about the 8 pin connector labeled "REMOTE" found on the back of the camera on the rightmost side that is largely used as a paint box connector but it should have run/stop capabilities.
This paint box unit has a run/stop button in the upper right hand side of the console...
Sony RMB-750 Remote Control Unit for BVP/HDC RMB750 B&H Photo
Old March 30th, 2011, 04:12 PM   #12
Re: Run/Stop?
Dear Andrew,
Yes, we are talking about the Remote Connector.
Dan Keaton
Augusta Georgia
Old March 31st, 2011, 03:00 PM   #13
Re: Run/Stop?
I'm pretty sure this is a proprietary sony connector though it's similar to a hirosi. I had an rmp 150 open on a gig yesterday doing some light repair work and I forgot to trace back the rec/run button to a pin out. If we can figure the pin out and someone can find a connector it wouldn't be too hard to fool it into starting and stopping. On the other hand there's a ton of circuitry in those little rmb there might be something more convoluted then a simple start stop signal.
Old March 31st, 2011, 05:25 PM   #14
Re: Run/Stop?
Dear Nick,
We currently feel that we can design a start/stop.
We just need to determine the exact connector.
Dan Keaton
Augusta Georgia
Old March 31st, 2011, 06:34 PM   #15
Re: Run/Stop?
I had a closer look, and your right it's not the Tajimi as the key is in the wrong place. It might be the Hirose MXR, but I don't have one to confirm just pics on the net.
