Sony announces the XDCAM EX - Page 19 at DVinfo.net
Old June 17th, 2007, 07:37 PM   #271
Originally Posted by Paulo Teixeira View Post
4,000 dollars is pretty steep for your average person.
Thomas Smet took the words right out of my mouth, in his post above... XDCAM EX is not at all intended for the average person.
A unit like this should cost 1,000 dollars and the discs would only be around 10 dollars each...
We're already there. It's called AVCHD.
Old June 18th, 2007, 01:02 AM   #272
Sony should at least make a portable Blu-Ray drive that is compatible with HDV and AVCHD if they worry that having compatibility with the XDCAM EX may threaten the sales of XDCAM drives. In this case, a laptop with a built in Blu-Ray drive is your best solution if you’re on a tight budget and there are already drives that are 4X write speed, that’s a little over 4X real time. Basically 1 hour of XDCAM footage will take just under 15 minutes to burn to a disc.
Its too bad Apple doesn’t offer a Blu-Ray drive as an option yet.
Still, like a lot of people are hoping, having compatibility with something similar to the PDW-U1 is a very smart move even if it costs up to 5,000 dollars. I can really see a market for this.
Paulo Teixeira is offline   Reply With Quote
Old June 18th, 2007, 12:13 PM   #273
Images: 1
Where are you getting these 4 or 5 thousand dollar prices from? I believe the PDW-U1 is expected to sell for around 3K. Again, the XDCAM EX is not a consumer product and the necessary support equipment isn't going to be showing up at your local big box store with dirt cheap, loss leader pricing.
The PRIMARY market for the PDW-U1 is going to be as a stand-alone ingest device. This is something many post-houses or broadcast facilities can invest in for taking in XDCAM HD without owning dedicated XDCAM HD decks. The decks have their place, but for a facility that just needs to take in the occasional client supplied XDCAM HD footage, the U1 is the right ticket at the right price. And don't forget, when it first comes out, it won't even support writing to disc. That functionality is expected via a software upgrade early next year.
-gb-
Old June 18th, 2007, 12:22 PM   #274
I don't know if this has already been announced whether the EX will write proxies in SxS cards?
Old June 18th, 2007, 01:52 PM   #275
-gb-
That’s only because I heard someone say 4,000 dollars for the PDW-U1 so I added up to a grand to that for a unit with more features.
The real point I was trying to make since the beginning, is for Sony to release a portable XDCAM unit so that you don’t need a computer, that’s it.
Old June 23rd, 2007, 12:03 AM   #276
just in passing....
i shoot for a number of organisations, incl. national broadcasters. i don't see them paying for cards!!! in house stuff maybe, but stringers and run and gun - no way..... tape is alive and well....
leslie
Leslie Wand is offline   Reply With Quote
Old June 23rd, 2007, 08:35 PM   #277
Our ABC just bought close to 100 HVX200s, guess they'll be buying at least some cards for them.
Old June 24th, 2007, 12:20 AM   #278
well hello there bob, fancy meeting you here!
they might have bought them - but are they going to send me one or two cards up when they want me to shoot? do i send them mine? we're not talking $10 tapes here, and i've had experience with ALL the major broadcasters not returning tapes, let alone cards....
leslie
Old June 24th, 2007, 06:11 AM   #279
I bet the workflow will be more like: shoot on flash, transfer to XDCAM disk, portable hard disk or Blu-Ray DVD and send THAT to the network, rather than the flash card.
Yes, it's an extra step. But keep in mind that this should be a relatively speedy file transfer operation, rather than a real time capture.
And who knows? Maybe the flash media will eventually get cheap enough that you can treat it like tape.
http://www.prolefeedstudios.com/blog/
Documentary for the masses!
Brian Standing is offline   Reply With Quote
Old June 24th, 2007, 06:26 AM   #280
Although transferring off the XDCAM EX cards could potentially be very quick, transfer to XDCAM disk is just under twice as fast as real time at 35Mb/s. So if you've shot 90 minutes footage, you're still going to need to find almost an hour to transfer to XDCAM (by the time you've setup the transfer gear).
Alex
Alex Leith is offline   Reply With Quote
Old June 24th, 2007, 10:37 AM   #281
Hmmm... I didn't realize writing to XDCAM disc was so slow.
Hard drives should be pretty fast, though. They're getting cheap enough these days that they're starting to rival tape in terms of cost per gigabyte.
I could envision handing off a $40 portable SATA drive with several hours of footage on it as a reasonable media for broadcast use.
Old June 24th, 2007, 10:35 PM   #282
As for the cost of this camera
At NAB I asked the Sony guy the expected price point, and he said it would be more than the Z1, maybe in the $7-9k range. I saw this thing (okay, in a glass case) and it was pretty impressive looking (large, well built looking). I don't think you should expect this thing to come in at the prce range of an FX1
Brian Mills is offline   Reply With Quote
Old June 24th, 2007, 11:05 PM   #283
Images: 1
I think the newer gear is going to be much faster. What XDCAM device are you transferring to in that example above? That's one of the advantages of shelling out for the F-70 deck is that it has about twice the file transfer rate as the camera (F330/F350) does.
With the new flash cards, using an express card 34 reader, you should get some very fast transfer rates onto your hard drive. You can then do a long term archive to professional disc at a later time of your choosing.
-gb-
Old June 25th, 2007, 09:29 AM   #284
-gb-
Theoretically all single laser XDCAM HD products are limited to 72Mb/s. I've never used the PDW-F70, so I can't comment about that - but the best you could ever hope for out of a single-laser unit is about twice real-time (if you're working with 35Mb/s material).
Dual-laser systems are capable of 144Mb/s, but they'll be more expensive.
You're absolutely right about hard drive transfers potentially being much quicker. Using a 160GB Hitachi 5K 2.5in drive (faster across the whole platter than their 7K drives) you could sustain a transfer speed that maxes out Firewire 400 - thus transferring 35Mb/s footage at about 11x real time (transfer 90 minutes of footage in 8 minutes).
I hope Sony integrate a hard drive controller into the EX (like the HPX500) so that the camera could control "dumb" portable hard drives to dump material onto over firewire...
Alex
Old June 28th, 2007, 05:32 PM   #285
I've been following with much interest the press on the upcoming EX as I think it might be my next cam. So I was really excited today to recieve Sony's XDCAM HD Disc Set and could finally get a good idea what XDCAM HD footage looks like on an SD DVD. Wow what a disappointment. I was playing it back on a high-end JVC player and 32 " Aquos LCD which was properly adjusted. Colors were drab and contrast extremely low on the Iditarod video. Orange/red colors, can't tell which, seemed to bleed. Snow was dingy and not crisp. This is contrary to everything I have read about the F-350.
What's going on here, do you think I just got a bad disc?
Regard
Mark Williams is offline   Reply
