Reducing yellow in EX1 at DVinfo.net
Old July 21st, 2013, 05:01 PM   #1
Hi there.
I have a much loved EX1 (still working hard after all these years!) and im thinking I might need to tone down the yellow a little in the settings. When matching with my FS100, even with correct white balancing etc, Im needing to adjust the tone of the EX1 in the edit to better match the FS100. The EX1 has a more 'yellowish' look when side by with FS100 and 5N.
Has anyone encountered this, or have any suggestions for setting adjustments in the PP that may help?
Jamie
Jamie Roberts is offline   Reply With Quote
Old July 24th, 2013, 01:10 PM   #2
Re: Reducing yellow in EX1
You might want to try the matrix settings from the profile I have here:
XDCAM-USER.COM • Login
Old July 24th, 2013, 07:52 PM   #3
Alister, would you mind reposting that link? It currently goes to a login page, and when I search for Matrix the bulletin board tells me it's too common a word!
Mark
Mark Morreau is offline   Reply With Quote
Old July 28th, 2013, 05:00 AM   #4
Thanks Alister
I found your recipes starting with the 'Vivid' settings in the forum. Is this the one you mean?
Old July 28th, 2013, 01:59 PM   #5
You have to register on the board to access all the setup file and picture profile sections. I lot of hard work, time and effort goes into the profiles so there only open to registered users. But registration is free.
Old August 5th, 2013, 01:26 AM   #6
Will take a look and sign up Alistair. Appreciate all your work.
