remote feed from ex1r at DVinfo.net
Old July 18th, 2013, 06:43 PM   #1
im shooting a wedding in November and the church will not hold all the guests, about 600 so far.
brides mother wants me to simulcast it outside in a courtyard for the overflow. would going out sdi be the best way vs hdmi? how long of a run can I do before signal degrades and I would need a booster in between. I would also be running audio out as well.
thx
Jim Stamos is offline   Reply With Quote
Old July 18th, 2013, 10:39 PM   #2
Re: remote feed from ex1r
By All Means SDI
Al Gardner is offline   Reply With Quote
Old July 19th, 2013, 06:48 AM   #3
SDI without a doubt and I run 100 foot cables from an EX3 all the time and see no degradation.
Jerry Porter is offline   Reply With Quote
Old July 19th, 2013, 10:40 AM   #4
This will b over 100ft,just need to figure where to rent it from here in houston
Old July 19th, 2013, 01:33 PM   #5
Why don't you just buy one and put it in the price? Don't get a cheap one though.
PROFlex Gepco HD SDI Cable VPM2000 BNCM 100 ft
Old July 20th, 2013, 08:48 AM   #6
SDI should be able to go close to 100 meters with no problem assuming you have a good cable like 1694a or 1505. Do you have a monitor that will take SDI?
www.marshallstaton.com
Marshall Staton is offline   Reply With Quote
Old July 21st, 2013, 12:56 AM   #7
going into a projector to show on a big screen. ill have to run audio as well, haven't look but im guessing theres rca audio outs on the camera
im sure this will be over 100 feet
Old July 21st, 2013, 01:04 AM   #8
Run it through a small mixer and come out XLR.
You need to make sure beforehand the projector can take SDI.
Old July 21st, 2013, 01:38 AM   #9
You can send audio through SDI.
Lukas Hribik is offline   Reply With Quote
Old July 21st, 2013, 03:43 AM   #10
I hope your not considering a projector outside in daylight, not a hope of anyone seeing anything!
Your biggest issue may well be that whatever large screens your going to use, unless your renting professional large screens they will probably be HDMI or DVI in. So, I would run the HDSDI from the camera using the best quality cable I can get. Close to each of the monitors I would use BlackMagic Hi5 to take the HDSDI and spit out HDMI (or DVI) plus RCA analog audio. You can loop the HDSDI through multiple Hi5's if you need to.
Whatever you do, as already suggested don't try to run the RCA unbalanced audio anything longer than 20ft. It will suffer from all kinds of interference. Balanced XLR will be better, but really you may as well take advantage of the digital audio embedded in the HDSDI which is highly immune to interference.
Alister Chapman is offline   Reply
