Ex1 footage importing with 4 audio channels?
I shot my footage with an EX1r and exported to MXF using the latest version of the EX Browser. When I bring the MXF files into a Premiere CS6 timeline it shows up with four audio channels but only two of them have audio. Any ideas on how to fix this?
Thanks, Marc |
Re: Ex1 footage importing with 4 audio channels?
That is something that Sony's media browser started doing. To stop it you will need to go back to v2.1 of clip browser.
http://www.LandYachtMedia.com |
Use the "Media Browser" tab in Premiere instead of exporting to MXF. Premiere CS6 is able to work with native XDCAM files if you retain the BPAV folder structure. You will then get 2 channels instead of 4.
Thanks for the replies. Marc
#5 |
I'm editing in Premiere CS6 and when I right click on the clips in the media bin and choose modify audio I can set the audio to two channels. Solved my issue and I was able to change all of the clips at once.
#6 |
Vortex Media
It's one of the best features of Premiere, and I really love being able to strip off all the audio channels of clips that don't need any audio at all.
Vortex Media http://www.vortexmedia.com/ Sony FS7, F55, and XDCAM training videos, field guides, and other production tools |
#7 |
the Media Browser tab in Premiere takes only the two channels from the raw MP4 files. There is no need to convert to MXF, and it works with spanned files. It's hidden by default, so you have to bring it up:
Adobe Premiere Pro Help | Importing assets from tapeless formats |
#8 |
Jack, I did not realize the media browser will work with clips spanned over two cards and thought I needed the EX Browser for that. I just started using Premiere for the first time (since Premiere 6.5) so I'm still getting up to speed. I ended up switching over for this project because Vegas could not handle the 440+ MXF files of my project without constantly crashing. Premiere CS6 is handling things remarkably and the real time effects are great. I can't see becoming hostage to the cloud but CS6 should serve me well for the foreseeable future.
Thanks, Marc P.S. Doug, thanks for getting me up to speed quickly on the EX1. Your DVDs are great. |
#9 |
Vegas can handle the native .MP4 files if you are on version 10 or higher. You only need to use MXF on spanned clips. If you want to avoid MXF alltogether, Premiere is a better option.
#10 |
Vortex Media
Thank you, Marc. It's always great to get that feedback.
#11 |
Vortex Media
Obviously that is a true statement because the MP4 files only have 2 channels to start with. But if you begin shooting with one of the newer cameras, such as the PMW-200/160/100, F5, F55, and the PDW-F800/700 that all shoot 50Mbps XDCAM HD422 MXF files natively, then you'll unavoidably be importing four stereo pairs of audio into Premiere with each clip. In that case, the MODIFY > AUDIO CHANNELS function is a godsend to quickly strip off the channels you don't want, rearrange them into a different order, or do whatever you want.
