Century Optics .6 Wide Angle Adapter on PMW-200
Used Century Optics .6 lens on my EX1R without fault, With the PMW 200 there is a problem with focus on occasion. Yes the camera is set to macro, and I am on the current firmware. I use autofocus mostly. Anyone else have problems with this lens? Anyone using similar lenses on this camera?
thanks... |
Re: Century Optics .6 Wide Angle Adapter on PMW-200
Is the Wide Conversion option in the menu system turned on? If it isn't, that's the problem.
If that's not the problem, I'm thinking it is because the Macro switch is on. AF + Macro switch don't mix. I've experienced this with the EX1R and it should be the same on the 200. |
Yes, wide angle is on in the menu, This lens requires use of macro and AF, manual focus does not work with this lens. I've used it on the EX1R for about 5 years.
thx |
Jack, the lens is not zoom through and relies on the use of Macro to bring it in to focus.
Ashley, manual focus is the best way to use the lens, but then you can't change focal length as this shifts the focus. Auto focus is suggested as autofocus can to some degree help shift focus as you zoom, but it's basically a fudge to try to make the lens do something that it can't really do.
Alister Chapman, Film-Maker/Stormchaser http://www.xdcam-user.com/alisters-blog/ My XDCAM site and blog. http://www.hurricane-rig.com |
#5 |
On a slightly different subject but staying with the PMW-200.. Does anyone know if Sony will release a version of this but with interchangeable lenses? That really was the ONLY reason for not choosing this camera.
Against the Canon XF-305 for image quality I rate the PMW-200 as the winner, especially comparing in low light. |
#6 |
Vortex Media
Well, you could always get an EX3. You'll give up 50Mbps 422, but you gain a removable lens, a more ergonomic desgin, and a much better viewfinder.
Vortex Media http://www.vortexmedia.com/ Sony FS7, F55, and XDCAM training videos, field guides, and other production tools |
#7 |
Can you get your hands on the Sony wide angle adapter? Its not as wide but it is zoom through.
http://www.LandYachtMedia.com |
#8 |
The Century Optics .6 (and Fisheye) ARE partial zoom through lenses. I don't think they were designed that way, but you can zoom about 25-30% of the way through the lens before you lose focus. I've used both extensively on an EX3 and never had any issues whatsoever. In fact, I have loved having that little bit of zoom available for a quick change in framing. Using these types of adapters, you do have to have the macro on, and the auto focus ON initially (so the camera can macro focus) then you can take the auto focus OFF. No need to keep it in auto as DOF is pretty much a few inches to infinity. The only time I've had to adjust focus (which you can do manually once you follow the first steps above) is when something is literally less than 5 or 6 inches from the lens. These adapters are super lightweight (compared to the full zoom throughs) and easily fit in a pocket. I recently bought a dedicated wide lens for my EX, so I no longer use these, and am reluctantly going to part with them. (I have a .6 w/shade and Fisheye in perfect condition if anyone's interested)
www.zooprax.com |
#9 |
Unfortunately the Century Optics are not zoom through (their website indicates this as well). You can get around it some by using autofocus and macro settings as noted but it is not the same as using the WA adapter the firmware in the camera is programmed to use.
If you need to zoom while using a WA adapter the Sony adapter is the only choice for complete compatibility.
#10 |
or better yet Zunow, Century Optics has too much barrel and CA, but that's all subjective of course.
I love this place! |
