SDI out to a SDI to SD converter into an SD video mixer, will this work? - Page 2 at DVinfo.net
Old March 19th, 2012, 04:47 PM   #16
Re: SDI out to a SDI to SD converter into an SD video mixer, will this work?
Originally Posted by Les Wilson View Post
Also, page 150 of the manual shows you can set it to record in SD format and output DVCAM to the firewire port
That is a feature of the EX1r. The original EX1 could not record SD.
http://www.LandYachtMedia.com
Old March 19th, 2012, 07:04 PM   #17
So he tried hooking it up to his mixer through the SDI output outputting an SD signal:
YPbPr/SDI Out - set to SD
Video Out: Off
Setup (blacked out)
Down Converter: Squeeze
Not seeing anything. The video is 1280x720 30p HQ.
Is there a menu I'm doing it wrong?
EDIT: He's connecting this to a monitor with a BNC component cable through the SDI output.
Jeremiah Warren is offline   Reply
