Motorized pan head for timelapse? at DVinfo.net
Old August 19th, 2011, 04:54 PM   #1
Does anyone have any experience with a decent motorized programmable pan head?
I will be doing some timelapse work with my EX3 and would love for one series to have a pan involved, but would need something with very slow speed so when the timelapse is played the pan will look normal speed. Ideally, I'd like something I can program the speed to a very slow crawl much like the clock drive in a good telescope. I need to be able to mount this on a normal tripod, and it needs to be able to hold about 20lbs or so. (the EX will be mounted with V-mount batteries, and a very large (and heavy) wide angle adapter. Renting would be preferred if possible. I've found some options, but they don't seem to be able to handle the weight....
Anyone have any advice?
www.zooprax.com
Derek Reich is offline   Reply With Quote
Old August 20th, 2011, 07:01 AM   #2
Sponsor: Westside AV
Re: Motorized pan head for timelapse?
I can rig up a very sturdy manual/programmable pan head for you, and I could do it as a rental if you like.
Contact me direct.
Old August 20th, 2011, 09:34 AM   #3
lots of people use a very popular and cheap telescope mount.
Orion Telescopes: Orion TeleTrack GoTo Altazimuth Telescope Mount
depending models you can program from remote control or PC several point.
Some even modified the motors, programming or some other parts to adapt cameras or DSLRs.
Old August 20th, 2011, 05:57 PM   #4
Thanks Olof, Giroud-
Both good ideas, but not exactly what I'm looking for. (the telescope drive is pretty close, but the weight limit is too low)
I think the Kessler turntable might work, but still trying to find some more information and rental options on it.
I'm open to anyone else who has any ideas, but this has to be able to handle the weight of the EX.
www.zooprax.com
Old August 20th, 2011, 06:23 PM   #5
lot of people also use the MEADE head, because it was made popular by Milapse.
The are some hacks for this head
MILAPSES! They're back! - Telescope Warehouse
some people use it with an EX1.
If the mount is properly balanced, even the weakest mount is ok for an EX1, since movement are very slow and almost no inertia is involved.
Old August 20th, 2011, 06:27 PM   #6
also OpenMoCo is a nice ressource for all about controlling cameras, they have a lot of ressource for timelapse and the MEADE head.
Old August 21st, 2011, 06:18 AM   #7
Thanks for the additional tips, Giroud-
I'll look into these.... seems like a possibility. Ironically, I have an old Celestron 8" telescope with drive, and briefly considered somehow modifying the mount to handle the EX, but there was no logical way to get the EX to fit on this one, at least not in the short amount of time I have available to pull this off! Plus, the tripod is pretty bulky and no reasonable adjustment for height.
I appreciate you help-
cheers
www.zooprax.com
Old August 21st, 2011, 06:37 PM   #8
I use the Teletrack and it's just fine with the EX1. Great for really slow pans etc.
Old August 21st, 2011, 07:01 PM   #9
Dont know if this would work but I'll throw it out there...I have a Kessler Revolution Head with the Oracle controller. It can go really slow...and could certainly handle the weight. Don't know if it goes slow enough and it is on the pricey side. It's programmable and does both pan and tilt.
Robert Turchick is offline   Reply
