Rewrap XDCAM MOVs back to MP4 files? at DVinfo.net
Old August 6th, 2011, 05:38 PM   #1
Howdy...
I have a bunch of XDCAM EX MOV files from Macs that I'd like to Re-Wrap back to MP4 files without transcoding, so I can use them on Windows without using the QuickTime plugin.
Anyone know how this can be done? Ideally in a batch workflow?
Best,
Ben
Ben Freedman is offline   Reply With Quote
Old August 6th, 2011, 05:54 PM   #2
Re: Rewrap XDCAM MOVs back to MP4 files?
Convergent Design makes an application that converts XDCAM MOV's to XDCAM MXF files. It's a free app so you could give that a try.
Here's a link to their downlaod page:
Downloads | Convergent Design | Professional Video Recorders and Converters
Food luck,
Garrett
Garrett Low
www.GLowMediaProductions.com
Old August 6th, 2011, 08:10 PM   #3
Thanks for that. Found a free solution that does a similar job, although it wraps to MXF, not MP4. Still, Premiere in Windows recognizes it just fine:
1. Aug 6, 2011 6:55 PM in response to: BenFreedman
From Colin Brougham:
Fo' sho' you can... well, not back to MP4. I haven't figure that one out, but I've got a solution to rewrap them as MXF that makes them work just fine on a Windows machine (Premiere Pro, anyhow) without any purchased software:
Download this file:xdcamfix.zip
Extract the EXE and BAT files in the same folder as the MOVs.
Double-click the BAT file.
Profit.
Any problems, let me know... but so far, two satisfied customers can't be wrong.
Old August 6th, 2011, 09:13 PM   #4
You can do it with XDCAM browser or Clip Browser by using the Import function to import the MOV's back into a BPAV folder as MP4's, re-creating the correct file structure. Tedious as you can only do one clip at a time but it works.
We can't say this enough on these boards: ALWAYS back up the BPAV folder. It is your master and the only thing that is really cross platform compatible.
Alister Chapman is offline   Reply
