Thread Tools
Search this Thread
Filming Peregrines
Hi, trying to film peregrines with my ex3 with the standard lens in flight ie stooping and chasing prey i want to slow it down in post, any ideas how to get the best results i do have a nano too
thanks Ian
Ian Thomas. Thomas Video Productions |
#2 | |
Re: Filming Peregrines
Set the camera to NTSC and 720p60 Set nano to I-Frame at the highest bitrate your CF card can handle. Shoot the peregrine. Open your clips with Cinema Tools, choose batch conform, choose the desired framerate (24, 25 or 30). I am in pal country, so take 25. Now Compressor have made a 25p clip of the 60p footage, so slowed it down 2.4 times. Last edited by Cees van Kempen; July 7th, 2011 at 12:38 PM. |
thankyou Cees
But i use casablanca to edit, why the high bitrate i frame and 720
720 because the EX does not record 60 fps in 1080. The highest bitrate because the bitrate per second will also be divided by 2.4 when you slow down from 60 frames to 25 frames per second.I-frame because Cinema Tools can not deal with Long Gop, unless you transcode it to a I-frame codec before doing the exercise.
