EX-1 went green at DVinfo.net
Old May 22nd, 2011, 12:33 PM   #1
EX-1 went green
Yesterday while white balancing outdoors my Ex-1 suddenly went stark iridescent green.. I turned the camera on and off and pulled the battery repeatedly then finally did an all-reset all to no avail. Finally I went to playback mode to see the previous shots and had full color. When I switched back to record mode it was fine all day.
What the heck happened? Will this happen again? Does it need to go in for repair?
Old May 22nd, 2011, 01:44 PM   #2
Re: EX-1 went green
Mine has gone green before after a colour balance but you can re-colour balance and it's fine. Seems to be an occasional bug in the firmware and to be honest I've not seen it since I upgraded the firmware.
Marcus Durham
Media2u, Corporate Video Production For Your Business - http://www.media2u.co.uk
Marcus Durham is offline   Reply With Quote
Old May 22nd, 2011, 02:48 PM   #3
Re: EX-1 went green
I've also had this happen to my EX1 (similar, but different):
YouTube - ‪EX1 freaks out‬‏
Damp camera, easily cured, never had a problem with it since. But I did need a little sit down somewhere after witnessing the freaking problem.
EX1 x2, C100 --> FCPX & PPro6
Old May 22nd, 2011, 03:30 PM   #4
Re: EX-1 went green
scary as hell, and as I recall it did happen to be before but was faster to fix. I'm wondering if "switching to playback mode" always works t fix it, or did I need to do an all-reset which is really a PAI since then I had top sit down and manually redo all my settings. Also it would be good to be able to tell someone who rented the camera what to do.
Do you guys remember what steps you took to fix it?
Old May 22nd, 2011, 03:34 PM   #5
Re: EX-1 went green
Hi
After upgrading the firmware I have not had the problem ! Do not remember the version of my first firmware.
Bo Skelmose is offline   Reply With Quote
Old May 23rd, 2011, 01:35 PM   #6
Re: EX-1 went green
It happened to me, as well. In my case, the culprit appeared to be exposure. I was trying to white balance while the lens and ND settings caused the image to be grossly over exposed. It was a very bright day.
I tried re-white balancing, switching the camera off-on and finally, a total menu reset. All brought me back to the same glowing green screen. Then I realized that the ND was on "0" and the lens, (set to manual) was wide open. I stopped down, white balanced and all has been fine since.
On the outside I appeared calm. Inside I was freaking out in three languages.
Chuck Fishbein is offline   Reply With Quote
Old May 24th, 2011, 04:48 AM   #7
Re: EX-1 went green
I think chuck has hit the nail on the head, I have had exactly the same thing happen on my EX1 and my Canon 550D. Always in very bright weather, and overexposed when balancing
Colin
Colin Rowe is offline   Reply With Quote
Old May 26th, 2011, 06:34 PM   #8
Re: EX-1 went green
I was balancing when it happened also and it may have been overexposed as I was outside.
I don't recall whether I just tried white balancing with a better exposure before I did all that other stuff.
Colin, what did you do to fix it?
550 also???!!!!! how'd you fix that one?
Old May 27th, 2011, 06:20 AM   #9
Re: EX-1 went green
Happened to me the other night. It was definitely due to white balancing while way overexposed. I turned the camera off, set iris to auto, turned camera on and re-white balanced. It did the trick.
Jim Rogalski is offline   Reply With Quote
Old May 28th, 2011, 05:08 AM   #10
Re: EX-1 went green
Simply took the camera indoors, switched it off/on and rebalanced indoors, went outdoors, set correct exposure and set balance, all fine. Procedure worked on both the EX1 and 550D. The problem is definately caused by trying to balance, when overexposed.
Colin
Old May 28th, 2011, 02:05 PM   #11
Re: EX-1 went green
I had the same thing happen a few months ago with my EX3. I fixed it by changing to the preset WB which fixed the image and then re-WB'ing.
Steve Kalle is offline   Reply
