media help at DVinfo.net
Old May 5th, 2011, 04:10 PM   #1
media help
Hey i own a few mxm adapters and cards
can you use more than one card in the slot when its full?
or is it one card per adapter?
thanks
Ollie Walton is offline   Reply With Quote
Old May 5th, 2011, 04:17 PM   #2
Re: media help
Hi Ollie
I use the MxM adaptors too along with ATP Cards
I keep the card in the adaptor at all times.
I could have 8/9 of these so no need to take the card out at all.
Anthony McErlean is offline   Reply With Quote
Old May 5th, 2011, 04:18 PM   #3
Re: media help
yeah can you change cards over.
or is it 1 card per slot. meaning once the 16gb has run out can you put another 16gb in its place?
Old May 6th, 2011, 02:30 AM   #4
Re: media help
Hi Ollie,
What camera are you using?
My EX3 has two slots, A and B.
When the card in slot A is full it carries on recording onto the card in slot B.
You then take out the MxM adaptor thats in slot A and replace it with an empty one so when the card in slot B is full it then returns to the empty card in slot A and so on.
Hope I've explained this properly.
Old May 6th, 2011, 04:27 AM   #5
Re: media help
hey sorry i mean
you know the mxm adapters you can use sdhc cards
can you only use one inside it or can you use as many sdhc cards as you want?.
or is it once you filled up the card you have to use another card and adapter?
thanks
Old May 6th, 2011, 06:49 AM   #6
Re: media help
You should eject the adapter once the card is full (while the other adapter/card is recording in the other slot). Then replace the card with a fresh one. Don't eject the card itself from the adapter while it is in the camera.
John
John Peterson is offline   Reply With Quote
Old May 6th, 2011, 07:17 AM   #7
Re: media help
hey sorry i mean
thanks
Juggling SD cards on location is asking for trouble. Good media management dictates that you should have one adaptor per SD card. Do your card wrangling away from the pressure of a shoot.
My SD cards never leave their adaptors. The cost is so low why create problems?
Marcus Durham
Media2u, Corporate Video Production For Your Business - http://www.media2u.co.uk
Marcus Durham is offline   Reply With Quote
Old May 6th, 2011, 07:28 AM   #8
Re: media help
yeah i thought that just wondered if anything happened
i mainly shoot 60d now, i use my ex1 a lot for live events and use my 35mm adapter sometimes for films.
have a short out soon which i shot on the ex1
will post later :)
