EX1R clip in premiere cs5 at DVinfo.net
Old April 21st, 2011, 12:00 AM   #1
Hello, if I can someone help me with advice,I filmed a concert a few days ago, now I tried to edit it in adobe 5.0.and surprise, when I look at the XDCAM browser video clip real length of 28 minutes, but when I import in adobe import only 13 min
Where is it wrong? before everything was ok when I was EX1, stuck clips automatically when you import in adobe, is a setting on the camera?
Thank you
Docea Marius is offline   Reply With Quote
Old April 21st, 2011, 12:46 AM   #2
Re: EX1R clip in premiere cs5
Maybe you have imported only the second part of the clip?! With 28 min it should have 2 or 3 parts. If you choose part 01 for importing, Premiere will take all parts. If you started with 02, Premiere will probably take only the rest. You have to start with the mp4 file in the first folder...
What is missing? The start, middle or end?
Markus Klatt is offline   Reply With Quote
Old April 21st, 2011, 01:11 AM   #3
Hi Markus, what you say is the true, the file is made up of three linked videos, but when I import in adobe, adobe import only the first part :-)
Is just a folder with a clip of 28 minutes, may need to set the camera Setting the timecode?
Old April 21st, 2011, 01:15 AM   #4
I never had such a problem. I don't even know, what timecode setting I do have in my EX1R.
But for the first: you can import the 3 mp4's one by one to get the full show. But I don't know how to solve your importing problem.
Old April 21st, 2011, 02:02 AM   #5
I use Premier CS5 and film entire theatre productions - up to one hour in length. I use ClipBrowser to transfer the files to my hard drive and then use the Media Browser in Premier to bring in the entire show, never have any problems doing it this way.
Old April 21st, 2011, 07:25 AM   #6
So I did and everything worked perfectly until now , I think to uninstall the browser clip
Interestingly windows tabs appear in three clips with the same name but numbered 1,2,3 and the XDCAM browser is only one clip 28 min
Old April 22nd, 2011, 12:08 PM   #7
Normally when you import movies sxs card import XDCAM clip browser,Normally when the video camera filming more than make up the 4GB file and finally import the clip browser when you are then automatically merged into a single video clip.
and video files automatically browswrul united, now if I look in the clip sxs card only see a file browser and do not say it is a file from multiple clips video unit.I think the clip browser connects not only longer videos clip show that takes 20 minutes but when I copy them into the computer he joins them into one long movie,
somewhere there is a possibility to set clip spans
Plese help my
Old April 26th, 2011, 02:46 AM   #8
Just import the BPAV-folder (yes the complete folder, not just the contents) into Premiere and all clips will be fine.
Brainstormnavigator searching for the hole in the sky.....
Audiovisual Designer (NL) - http://www.brokxmedia.nl
Walter Brokx is offline   Reply With Quote
Old April 29th, 2011, 12:31 AM   #9
Thanks Walter
I managed to solve the problem,I reinstatal entire system from 0.I say were a little messed up codecs
Marius
