Any way to rename clips in the BPAV structure? at DVinfo.net
Old April 5th, 2011, 05:08 PM   #1
Shooting a piece over an extended period I've found I've managed to duplicate clip names. No that big an issue really except I like to merge them all into one BPAV or export them as MXFs into one folder. I had thought the Clipbrowser would have the smarts to rename clips but it seems not. Anyone know of a way to do this?
Old April 5th, 2011, 06:52 PM   #2
Re: Any way to rename clips in the BPAV structure?
Bob,
Can't you combine the folders?
Right click the folder in the tree view of CB and select "Combine".
If I am misunderstanding what you are trying to do there is another way if you have a USB Hard Drive recorder and an Expresscard to USB adapter. Not sure how much data you have, but you can put the cards one after the other into slot A and have the recording setup in slot B. You can then record from slot A to slot B. It will create a single BPAV folder renaming all the clips in the process. I made my own, but it is just like this one:
http://e-films.com.au/shoppingcart/p...corder%29.html
It operates like this:
http://e-films.com.au/shoppingcart/p..._userguide.pdf
John
John Peterson is offline   Reply With Quote
Old April 6th, 2011, 05:46 PM   #3
John,
yes, normally I can combine folders. I haven't tried combining them when they contain identical clip names though. Maybe that's one way to force a rename.
Bob Grant is offline   Reply
