Fastest SxS card reader at DVinfo.net
Old March 14th, 2011, 09:14 AM   #1
So I am looking to get a fast SxS card reader to ingest my EX1's video for my new computer build. Any suggestions?
The system is:
Zalman Z-Machine (water cooling installed)
i7 990 mild o'clock at 4.0GHz
12 GB OZC 1333 ram
2 Seagate 7200.12 1T in RAID0
HD 6870
All in all it is a nice quiet machine for hobby video and light gaming.
I will soon add a SDI interface but may need to upgrade the RAID or add a SSD to keep up with the data stream.
Charles Young is offline   Reply With Quote
Old March 15th, 2011, 09:28 AM   #2
Re: Fast SxS card reader
Is anyone using a SXS card Reader?
Old March 15th, 2011, 10:02 AM   #3
Re: Fastest SxS card reader
I dont know about the fastest but I use the SxS & MxML PCI-e READER.
I'm very pleased with it.
Anthony McErlean is offline   Reply With Quote
Old March 15th, 2011, 10:15 AM   #4
Hi Charles,
This is what I use in both of my PCs
This is the fastest connection available.
Old March 16th, 2011, 01:02 PM   #5
Steve, would this work in a Mac Pro?
(I read the tech specs but couldn't see mention of this).
Malcolm
Malcolm Hamilton is offline   Reply With Quote
Old March 16th, 2011, 02:04 PM   #6
It should work in any computer with a free PCI Express slot. However, you might have to try various slots as Mac's are very finicky. I have one in my HP Z800 in a PCI Express x4 slot. I have an extra one and tried both in my Z800 but my PC didn't like that and kept rebooting when accessing a SxS card.
Old March 17th, 2011, 02:48 AM   #7
Unfortunately, the PCIe "bus" is not hot-swappable in most (if not all) PC motherboard BIOS'es.
My remedy is to boot my PC with any SxS card in the PCIe reader; then I can read another SxS card without re-booting, by following the following steps:
- "eject" the current card using Device Manager, then remove it physically
- insert another SxS card
- "mount" it by making Device Manager search for a new device
- repeat for yet another card
- instead of shutting down, just put my PC to sleep at the end of day...
This might seem complicated, but the time needed for those extra steps is nothing compared to time savings resulting from the copy speed of some 90 MB/s (vs. up to 30 with USB interface).
HTH
Piotr
Old March 17th, 2011, 10:43 AM   #8
Hmmm. This works for you on a PC, Piotr.
Does anyone who uses a Mac Pro have a solution?
thanks,
Malcolm
Old March 17th, 2011, 03:17 PM   #9
Hey Piotr,
What do you use for your nanoFlash? I just ordered a Lexar Expresscard CF reader to use in my Siig adapter but I don't have the USB connected on the Siig adapter. And what PCIe slot do you have your Siig adapter in? I tried a x16 slot in my HP Z800 but I had several lockups requiring a hard reset; so, I put it back in a PCIe x4 slot (x8 mechanical, x4 electrical).
Old March 18th, 2011, 01:18 AM   #10
Steve, mine is not Siig - but I guess they are all the same. It works fine in any of my PCIe slots, starting with the x1 ones.
As to reading the CF cards, I also use this same adapter but stick the SxS->CF adapter in between. Also up to 90 MBps transfers.
Piotr
Old March 18th, 2011, 07:08 AM   #11
Sonnet makes a PCI-e SxS (and more) reader. It's a $1K, but features 25x speeds and takes two cards at once. I love it.
Jacques Mersereau
University of Michigan-Video Studio Manager
Jacques Mersereau is offline   Reply With Quote
Old March 19th, 2011, 04:12 AM   #12
Correction: of course I meant an ExpressCard CF adapter!
Piotr
Old March 30th, 2011, 10:46 AM   #13
Originally Posted by Steve Kalle View Post
Hi Charles,
Amazon.com: Siig Jj-000082-S1 Pcie To Expresscard Bay Rohs-Compliant 40: Electronics
Steve
are you using SxS cards with that device? i purchased same one, but none of my SXS cards work with it, except MxM card.
David Borukhov is offline   Reply With Quote
Old March 30th, 2011, 10:53 AM   #14
Have you installed the SxS driver?
Old March 30th, 2011, 12:03 PM   #15
.My remedy is to boot my PC with any SxS card in the PCIe reader; then I can read another SxS card without re-booting, by following the following steps:
HTH
Piotr
Did you insert your SxS card into the PC as Piotr says before switching it on.
