Sony Ex3 Do I need a filter ? If yes Which one?
I have read about needing a filter and have seen some say get ones like the tiffen or the BW but I'm confused and dont want to spend a fortune on a filter. Please advise.
Thank you BK |
What filters are you talking about?
UV/ND/polarizer? I always have a UV filter attached to my lens, unless I need another kind of filter for a particular shot. The UV filter blocks out haze and is a nice way to protect your lens from getting scratched. I have B+W filters and have no complaints with them. |
I assume you are thinking about the dreaded infra red problem. The answer is yes, it will turn blacks black rather than muddy brown. A lot has been written about this on these forums. I use the Tiffen IR filter and it has saved the day on several shoots.
Eyes are a deaf man’s ears. Ears are a blind man’s eyes |
Yes, the IR filter is definitely a good thing to have in the bag.
I use the B+W IR filter...no complaints on this filter either. I don't use this filter much, but it is a great filter to have in the bag when blacks are looking brown. |
#5 |
I'd use the Tiffen T1. It's purpose designed for the job of removing IR on an EX1 or EX3 with as little impact on everything else as possible.
Alister Chapman, Film-Maker/Stormchaser http://www.xdcam-user.com/alisters-blog/ My XDCAM site and blog. http://www.hurricane-rig.com |
#6 |
I use the B+W 486. Stays on all the time.
-Garrett |
#7 |
#8 |
The 486 is an interference filter and like all interference filters this causes problems at wide angles with a distinct tint appearing in the corners of the image, appearing as a slight cyan vignette. It's much harder to cleanly remove a corner tint than the slight overall colour shift that the T1 introduces.
#9 |
Yes Alister, that is exactly why I don't keep it on all of the time... only when I need it. I like my wide angles to be as clean as possible!
#10 | |
What would happen if say for instance, the bridesmaids dresses were black and I hadn't the filter attached. That's just one example. |
#11 |
If you white balance through the T1 the very slight colour tint disappears.
#12 |
Well, it will depend on what fabric those dresses are made of, but I take your point.
#13 | |
That is the whole point... in that case you have determined that you need the filter attached. I don't do a tonne of live events so my shots are mostly controlled and I can use the filter when I need to. Excellent filter to have at your disposal though. |
#14 | |
Never heard of a bridesmaid wearing a black dress, maybe if they are then it would be better to leave the filter off :-)
#15 | |
I've recorded two weddings (as far as I can remember) when the bridesmaids wore black dresses. |
