Is there such a thing.. at DVinfo.net
Old December 31st, 2010, 01:02 PM   #1
I am looking for a cable out of the ex 3 that would be able to port to a monitor via dvi. is there a cable/gender chager box that would accomodate...hdmi ti dvi on the ex 3 ...sdi to dvi...etc?
Thanks in advance,
Dano
Dano Motley is offline   Reply With Quote
Old December 31st, 2010, 01:19 PM   #2
I believe you'd have to get a converter box like this one:
http://www.bhphotovideo.com/c/product/626535-REG/AJA_HDP2_HDP2_HD_SD_SDI_to_DVI_D.html
taking the SDI out into the box then into your DVI monitor. The EX3 does not have an HDMI out. If it did you could get a simple adapter or they even make cables that would do what you want.
Gefen also makes a box that would work - http://www.gefen.com/kvm/product.jsp?prod_id=2043
-Garrett
Garrett Low
www.GLowMediaProductions.com
Old December 31st, 2010, 07:42 PM   #3
Also should have mentioned that DVI does not contain audio.
-Garrett
Garrett Low
Old January 2nd, 2011, 01:43 PM   #4
Thank you very much.
