ntfs to fat32
Client sent a Western Digital Elements hard drive to transfer EX files to. It is a new NTSF drive out of the box.
I can't seem to find any way to reformat the drive for Mac/Fat32. |
I don't know about Mac, but if you can connect it to a PC, type the following in the command shell:
format "drive_letter": /FS:FAT32
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive |
Hi Ed,
To format a disk in OS X using Fat32 file structure, launch "Disk Utility", select the disk in question in the left-hand sidebar, then in the horizontal nav in the upper right quadrant select erase, then you will see a "format" drop down menu, select MS-DOS (fat) and then click the appropriate buttons from there. -Andrew |
I was thinking of doing a format on a PC in fat32. Any hangups at all in moving to a mac after a fat32 format on a pc?
#6 |
Applications > Utilities > Disk Utility. Select the drive in the left side, then click the Erase tab, change the format to either Mac OS Extended (Mac read and write only) or MS-DOS (FAT) (Mac and PC read and write, 4GB file size limit.)
#7 | |
THAT is what I couldn't find...simple. Thanks Ed |
