Ex-1 R battery drain fixed? at DVinfo.net
Old November 16th, 2010, 12:50 PM   #1
My original Ex-1 had a problem of battery drain when the camera was turned off. Anyone know if this was fixed with the Ex-1R?
When I first got the the Ex-1 by mistake I left the battery attached while driving home for several hours and found the battery exhausted when I tried to shoot again. I developed a habit of removing the battery before putting the camera in the bag (a good habit however). My first shoot with the Ex-1R was on a 9 day trip to Vermont and battery life was a constant worry since there was no way to recharge the battery along the way. When there was to be a hour between shoots I started removing the battery. It may have been unnecessary...
Has the battery drain problem with the EX-1 been fixed in the EX-1R?
Ronnie
Ronnie Martin
Kato Video
Ronnie Martin is offline   Reply With Quote
Old November 16th, 2010, 01:52 PM   #2
Ronnie
This is no longer a problem I sent my EX1's in to Sony and the circuit boards were replaced fixing the drain issue No charge..The EX1r does not have this issue.
Old November 16th, 2010, 04:34 PM   #3
The EX1R may not have the same issue as the EX1 but there is still a battery drain when powered off. I think an hour is as good a threshold as any to disconnect the battery.
Old November 17th, 2010, 03:48 AM   #4
Images: 10
How does this affect Swit batteries like mine, which power the camera via the 12v plug instead of powering through the normal battery terminals. I always take my batteries out so i have no idea if my camera still has the problem.
Old November 17th, 2010, 06:36 AM   #5
It affects my Swit as well as the BP battery that came with the EX1R. IT takes a day or two but it does drain.
Old November 17th, 2010, 07:46 AM   #6
Sponsor: Westside AV
I have an EX3 and an EX1R, both drain the battery in about 4-6 days.
As a matter of fact it killed one of my Sony 60 batts. I left it connected for a week or 2 when not shooting with the EX1R, by mistake. No warranty.
I am in the habit of always unplugging whatever batts are connected, whenever I will not be shooting within a few hours. That is I unplug my Swits, IDX, AB or remove my Sony batts on days I am not shooting.
Every camera I have ever had drains the batteries a little but the EX's seem to do this faster than any others.
Old November 21st, 2010, 07:37 AM   #7
Hi Olof,
Your post made me wonder whether it's safe to leave those long 96Wh batteries, connected into the EX1 DC-in socket. What do you think?
And, did you have your EX1's PCBs replaced for the battery drain?
TIA
Piotr
Old November 21st, 2010, 11:35 AM   #8
Hi Piotr,
I have an EX1R and the drain on that is the same as the EX3, not as bad as some reports on the original EX1.
I would not leave any batt in for long periods. That is how my Sony batt died. I typically turn the (inline to D-tap on the Swit) switch of to my NF and unplug the cable from the camera.
I try not ever leaving batteries in anything for more than a day or 2 when not in use, especially AA's, they can leak. I am also very careful about not leaving chargers on for long periods, they have been known to start fires. I have a friend who lost a house from Nicad charger.
I am now off to check out the new AF100.
