Aliasing problem Sony PMWEX1R at DVinfo.net
Old October 8th, 2010, 10:55 PM   #1
I am trying to transform from an amateur to a professional. I have one Issue with my new camera that no one is able to answer. When I shoot in hd or sd , in progressive or interlaced) (I think more in progressive) I notice when I move the camera, either panning or zooming, my straight lines start to move. I think it might be called Aliasing and it is driving me nuts. Are there any settings in the camera to eliminate this problem or is the an effect in FCP that I can use to eliminate this I tried the flicker effect on max and that seems to help, but at what cost to my picture quality. Is there an after market plug in i can buy. In the camera itself in the pic profile I found the setting called detail and I have turned that down to -30 which seems to help, there is also a setting called crisping which I haven't tried yet, am I going in the right direction. This aliasing CANT be a characteristic of this $6,299.00 camera I cant see giving a dvd to a customer with all that distracting Aliasing going on. Did my new camera just turn into a paper weight.... I did notice when I shot footage and watched it on my tv directly from the camera, (before going to FCP) the video looks great almost no aliasing at all. When I upload it to FCP using the XDCAM transfer software, from this point on thats when you begin to notice the problem. When I watch the video either in the XDCAM Transfer program or FCP, if I leave the video small thats when you see it. If i make the video big it goes away, UNTIL i burn it to a dvd where you see it all the time. Its driving me crazy... lol.
My work flo is 1. shoot in 1920/30p, 2.download to FCP using XDCAM transfer software, 3. edit, 4. then either share to dvd, or export to QTM then burn to iDVD. All of which is giving me a problem. Any advice you can give me I would really appreciate
Michael Armao is offline   Reply With Quote
Old October 9th, 2010, 03:31 AM   #2
Its all to do with the way that HD is downsized to SD (for DVD). There are plenty of posts on this forum that deal with this issue.
I too found this a big problem at the outset. I bit the bullet an purchased 100 blank DVDs and using a short clip I burned DVD after DVD making careful note of the settings used for each burn.
I have just published my latest DVD using these settings - Capture in 720p 24 fps. Edit in Premiere Pro CS4 & CS5. Export the time line as an AVI file 486p @23.97 fps (24fps) Open a new 486p time line and drop in the avi file. Export via Adobe Media Encoder as a MPEG2 DVD file using NTSC 486p Widescreen codec values Min - 2, Target - 6, Max - 9.
The resulting DVD is twitter free, sharp as anything I have seen from a blockbuster movie.
My advice - buy that stack of DVDs and try the permutations for your self until you have the desired result.
Old October 9th, 2010, 03:46 AM   #3
A nice quick and easy way to do this is to create a SD PAL or NTSC timeline in FCP. Prores is a good codec choice for this. Ensure your timeline is either progressive or interlaced depending on your source material.
Drag your completed video onto the timeline.
FCP will complain the video doesn't match the timeline. Do not let it alter the timeline parameters to match the video you are trying to load.
You now have a resized HD video on an SD timeline (it will look horrible until rendered). Apply any appropriate filters such as Broadcast Safe, and then export that timeline.
You now have an SD video which you can encode to MPEG in Compressor.
There are other methods but this is quick and easy.
Marcus Durham
Media2u, Corporate Video Production For Your Business - http://www.media2u.co.uk
Marcus Durham is offline   Reply With Quote
Old October 9th, 2010, 04:00 AM   #4
There are lots of ways to "skin a cat" Marcus, Adobe Premiere can also do it this way, but I have found the quality of down sampling to be less than satisfactory.
I should have added that I also have a Matrox RTX2 card installed and this has a very good codec.
Old October 9th, 2010, 05:06 AM   #5
Michael,
As already stated, this is not a camera issue but one of converting from High Def to Standard Def (DVD). The problem is explained nicely in Alister Chapman's blog here:
http://www.xdcam-user.com/
It's in the February 2009 section and the article is called: Getting SD from HD and the problems of oversampling.
http://www.xdcam-user.com/?p=4431
There's a wealth of excellent articles there about the EX1R. I recommend subscribing to it for your journey. Bottom line is to change your workflow as prescribed.
Last edited by Les Wilson; October 9th, 2010 at 07:37 AM. Reason: Provided alternate way to navigate to the article
Old October 9th, 2010, 05:16 AM   #6
Michael, as I've written elsewhere, ad nauseum, I had exactly the same problem as you with the horrible twittering DVDs (I'm PC with Premiere CS4 & CS5), and spent 1,400 hours one year (in off hours!) trying
everything short of some very esoteric solutions that had evidently worked for others.
Then I purchased Convergent Design's nanoFlash, and on EX-1 am recording DVI out to nanoFlash at 100Mbps, Long GOP, 1920 30p, with 422 colorspace, and not only do I see a better, cleaner picture on a 109 inch screen in HD (Blu Ray), but for the first time my HD downrezzed to 480x720 DVDs show up
what this camera can produce, without significant interline twitter on fine horizontal lines, and without a lot of garbage artifacts. Nuff said! And good luck to you.
William Urschel is offline   Reply With Quote
Old October 9th, 2010, 07:41 AM   #7
you lost me... lol
LOl everything you said I appreciate, but remember im a newbe and some of that stuff you said to do lost me.... I been going through dvd like crazy but still haven't found my look yet. I don't know if im doing it right. I need somebody to tell me the steps from FCP. My work floe now is I tape in 1920/30p download to FCP using the XDCAM transfer software I edit in my time line then when project is done I either 1. Export as QTM as same settings then burn in IDVD or 2. from time line I send to compressor choose the make to DVD from templet without changing anysettings, or 3. from time line I goto to file in FCP then choose share and that makes a dvd. all of those ways I have the problem. If I should be doing something different at any of those steps please tell me..
thank you
Old October 9th, 2010, 08:01 AM   #8
Sponsor: Westside AV
I have a few different workflows for creating different types of DVD's.
But here is a simple one:
Edit your 30p or whatever project in FCP in HD, until you are ready to export.
Then export the sequence either as self contained or by reference movie.
Then use Bitvice to make your MPEG file and AAC audio file. Bitvice is a fantastic way to create MPEG files in my opinion the best. It is available here:innobits.com - It is all about visions
Then drop those files into DVD Studio Pro, and author your DVD. You will love the result.
This is a really easy way to deal with HD to SD conversion for DVD's.
Others here may have different workflows that work well, but this is my preferred technique.
Old October 9th, 2010, 06:21 PM   #9
But the OP has Final Cut. There's lots of things Premiere is bad at. I should know, I spent 4 years of using it as my only editor before switching. The FCP scaler is much better than anything I ever used in Premiere. Perhaps Adobe have improved the scaling, who knows?
For most uses, the method I'm using seems fine in when viewed on a large screen TV. You can also do the scaling via compressor but if your end users will see the difference on their domestic TV's is debatable. We can all quarrel about how to get that final extra 5% quality in our downconversions, but since the end users don't all have Grade A broadcast monitors hooked up to their DVD players it becomes somewhat irrelevant.
Marcus Durham
Old October 9th, 2010, 08:28 PM   #10
To the OP, it's not your camera...happens with all cameras. Problem is in the downscaling as mentioned above. I have two paths I take depending on the length of the program. Since I edit in prores 1080 30P, here's the two workflows I use.
1) short programs...edit program in 1080 30P and export final to self contained pro res file same settings as sequence.
Open exported file in QT7 and export to 853x480 pro res file (this is faster than scaling out of FCP for some reason)
Put new file in Compressor and choose Best Quality 90 min DVD setting. Make sure it's seeing the file as progressive. This seems to be the one setting that matters most. Once done, take the compressed files into dvdsp and build your disk.
This has worked extremely well for me.
2) basically the same as above but for long programs I use a different export from QT7. Instead of pro res, I use h264 at a medium-high setting 2 pass. Also I do the same scaling to 853x480.
Rest of the steps are the same. Though in compressor, use the appropriate preset for the length of material. Usually I use this on material that is over 2 hours long.
The reason is hard to explain since a compression engineer suggested I try it. EssenntiLly, the extra transcode to h264 along with scaling works best and it has to do with h264 "smoothing" out the rough areas therefore the transcode to mpeg2 works more efficiently. It takes a lot longer but the results have been fantastic. Dont know if he was feeding me a line but it solved the same issues you describe.
The other benefit is I end up with a full hd file and a smaller h264 that I can youSendit to the client. Did this with my last 2-1/2 hr video and it turned out great!
Hope this helps!
Old October 10th, 2010, 05:12 PM   #11
Hi Olof.
I think I'll download the trial of the BitVice application that you mentioned. But I have a question as to your export settings from FCP to a movie.
Do you keep it in its native XDCAM EX settings or do you export it as ProRes HQ?
Thanks.
David Knaggs is offline   Reply With Quote
Old October 11th, 2010, 06:57 AM   #12
David, I always set my timelines up as EX timelines with rendering as Prores.
This way anything that needs rendering will be Prores, that includes color corrections, transitions, titles etc.
Anything that does not have cc or anything else will not be rendered, but Bitvice will use the original file a source. And this is fine.
This is if you export by reference. If you export self contained file use Prores422. I don't usually use HQ for anything. I find regular Prores to be fine.
Old October 11th, 2010, 10:21 AM   #13
Vortex Media
If my only output will be DVD (no HD output necessary) I shoot HD but I edit with an SD timeline. FCP does a great job of scaling right on the timeline; plus there are many other advantages of editing with an SD timeline that are too important to give up. There are no special plug-ins, 3rd party software, or other time-wasiting steps needed in the workflow. I edit in SD . . . output a QuckTime movie . . . run that movie through Compressor using slightly modified DVD settings, and then import the audio and video files into DVD Studio Pro. It's fast and simple.
However, if I DO need HD output, then I use an XDCAM sequence that matches the majority of my raw footage. I then use Compressors to rescale the footage for SD if I also need SD output. It's still looks good, but the rest of the workflow is not as simple that way.
My philosophy is to forget about what your raw footage is, and match your sequence settings to your output instead.
Old October 11th, 2010, 05:22 PM   #14
Why burn all these DVDs when you can watch the dvd's video on your computer either by creating the image and using something like PowerISO to mount it or by opening the VOB files in VLC.
Old October 11th, 2010, 05:49 PM   #15
Steve,
It's quite expensive to send a computer by DHL, far cheaper to send a DVD
Vincent Oliver is offline   Reply
