EX3 - Dark Images at DVinfo.net
Old October 7th, 2010, 09:08 AM   #1
EX3 - Dark Images
Hi, been using the EX3 for some time now, but never quite got around this problem....
The auto iris tends to leave images a bit dark. We always have to go manual and open it up a couple of stops. Even going into the menu and utilising the +1 stop setting to let in more light doesn't seem to make it much brighter.
I know its best practice to do it all manually, but sometimes we need to use auto iris for operational reasons.
Has anybody else had the same problem and did they find a remedy? TIA.
Steve Blackwell is offline   Reply With Quote
Old October 7th, 2010, 10:57 AM   #2
Its happen for me same, are you use Cin2 on PP?
Hirata Tomoki is offline   Reply With Quote
Old October 7th, 2010, 11:08 AM   #3
Never use auto iris. If you point it into the sky, or a bright area, it will make a dark image. Also with auto, your exposure is always changing, which makes for very amateur looking footage. You need a constant exposure to properly color grade in post. There is no legitimate reason to shoot auto. Just manually expose for the subject, and let the rest do what it will. You will always get the same results in auto.
My Work: http://www.youtube.com/ChadWork1
Sony FS5 :: Panasonic GH4 :: Sony PMW-EX1 :: FCPx :: AT4053b :: Rode NTG-3,
Chad Johnson is offline   Reply With Quote
Old October 7th, 2010, 11:10 AM   #4
I too have committed the "un-pardenable sin" of using auto iris. But my EX3 auto iris does a good job and I have been quite happy with the results. I have not noticed the problem you mentioned.
Just speculating here, but what if you focused on a gray card, manually set the level for it, and turned the auto iris on to evaluate the actual exposure changes rather than using a scene?
Then again, I usually shoot things adjusted down a stop or so below where it could be as a matter of personal taste.
I do find it hard to make adjusts to the iris when the camera is on the end of a jib 12' away.
Kevin Spahr is offline   Reply With Quote
Old October 7th, 2010, 12:41 PM   #5
Use zebra to get correct exposure. The aim is to get the shot as bright as possible without getting the brightest parts blown out. You may use only zebra 2, which is always 100%. So if you set you exposure so that zebra 2 just disappears, you are quite good.
I also use the histogram in the viewfinder to get a good exposure.
Sverker Hahn is offline   Reply With Quote
Old October 7th, 2010, 01:48 PM   #6
TIA.
With all due respect Steve, might I ask, and I am asking in a serious manner, what operational reasons cause you to use auto iris?
David Issko
Edit 1 Video Productions
David Issko is offline   Reply With Quote
Old October 7th, 2010, 03:11 PM   #7
For me I will use auto iris if I'm in conditions where the light changes dramatically and quickly and often and it's all one take... like in a forest going from shade to light to shade to light... or if a shot is really bright when wide and zoom in to a dark area... I can't change the iris on the fly as smoothly as the auto iris does for me. I've had no problems with auto iris looking unprofessional in the conditions I choose to use it.
If you're going from a dark scene to a bright horizon, especially when there are other things in the composition (people, trees, etc.) then you can't use auto iris because the darkening transition is not subtle, but if you're running/moving with the camera in changing light conditions it's usually quite subtle and better than one can do manually while composing and running. At least that's been my experience. If someone has a method of doing it better, I'd be all over it. I just don't see how you can manually focus, manually change iris, keep composition while moving fast in light that keeps changing.
Buck Forester is offline   Reply With Quote
Old October 7th, 2010, 03:14 PM   #8
It might be your EX3 because my EX1 does not shoot dark in auto iris.
Old October 8th, 2010, 02:47 AM   #9
Check your EV value is not set to -1 or other, Click on the aperture setting in the viewfinder to open up the EV values.
I never use Auto Iris on the EX3 although I do use a lot of Auto settings on the Canon XHA1 (mainly for wedding work when shooting scenes quickly)
Old October 8th, 2010, 03:21 AM   #10
In the cases your left hand is not availble and moving your right hand away from the grip will cause unhappy accidents.
Brainstormnavigator searching for the hole in the sky.....
Audiovisual Designer (NL) - http://www.brokxmedia.nl
Walter Brokx is offline   Reply With Quote
Old October 8th, 2010, 08:36 AM   #11
Thanks very much for your help guys, I'm very grateful that so many of you have put in your thoughts... back a couple of
I think so Hirata, I'm using PP5 which says "Cine" and the Gamma is set to STD3.
Originally Posted by Kevin Spahr View Post
.....Just speculating here, but what if you focused on a gray card, manually set the level for it, and turned the auto iris on to evaluate the actual exposure changes rather than using a scene? .
Tired that Kevin, thanks. I manually set it to what I thought looked good, but the shot went darker when I turned on the auto.
Zebra was set to 1 at 70%. I use Zebra when manually setting up a shot - but again, like with my reply to Kevin, switching back to auto and the scene goes a bit darker. I shall change the Zebra to 2 and 100% and see what the difference is.
Thanks Vincent, do you mean the TLCS > Level ? Thats set to 0.
Walter is kind of right David - creative jobs are fine, but some "operational" jobs move at extreme pace and the lighting conditions vary considerably (lit rooms, dark hallways). And your "free" hand is sometimes carrying a riot shield.
Old October 8th, 2010, 10:09 AM   #12
People say that zebra 1 at 70% gives you a good exposure of skin. You should see zebra on faces if you use it. When using zebra 2 you should not see any zebra at all. Quite different way to work, in other words.
Old October 8th, 2010, 12:44 PM   #13
Using 70% zebra to expose like it's 100% zebra will give you really underexposed images.
100% warns you for blownout highlights.
