#31 | |
I think I'm also correct in saying that chroma subsampling is also compression and will also reduce noise, slightly. What the SDI signal does bypass is the mpeg-2 compression, it also has better chroma sampling. I think the best example of the impact of compression on noise is found in the cheap AVCHD / H.264 palmcorders. Despite their very small sensor and slow lens in low light the image is pretty much noise free. It's also pretty much unwatchable due to the horrid macroblocking. |
#32 | |
The consensus is that for the uncompromising quality, one needs to record in I-Frame only at 220 Mbps or above. But I guess we're getting slightly off-topic in this thread :) Piotr
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive |
#33 | |
So, back to the thread's topic: - could you enlighten us about the Black Balance adjustment on the EX1? Is it done automatically indeed, or does it make sense to run it manually? Its very presence in the Maintenance Menu would suggest the latter - but then again, it's inactive in my EX1 (greyed-out)... - while we're at the Maintenance Menu: when you run the Back Focus adjustment, do you repeat it for all 3 ND positions as was touted in the EX1 early days, or is a single execution enough? Thanks, Piotr
#34 |
I believe the EX1 does a black balance every time you turn it on, but I cannot confirm this.
Alister Chapman, Film-Maker/Stormchaser http://www.xdcam-user.com/alisters-blog/ My XDCAM site and blog. http://www.hurricane-rig.com |
