Does Sony EX1-R flip/flop the signal?? at DVinfo.net
Old August 21st, 2010, 05:27 PM   #1
A question about this came up this weekend. If anyone who has one or has used one utilizing this feature could chime in and let me know if it actually does perform this flip/flop feature and is it applied to the output HDSDI signal or just to the viewfinder. The original EX1 doesn't do this so this question only applies to the "R" version.
Thanks for any info
Old August 22nd, 2010, 10:54 AM   #2
Yes, flip, flop or both. Records flipped/flopped and sends flipped/flopped over the outputs.
Old August 22nd, 2010, 05:17 PM   #3
Thank you Mr. Chapman
Old August 23rd, 2010, 02:42 AM   #4
Sorry, I have this camera - and had the non-R-version before - but I have no idea what this feature is about... Would you mind to to explain?
Thank you
Stephan
Stephan Hubenthal is offline   Reply With Quote
Old August 23rd, 2010, 12:58 PM   #5
@ Stephan:
if you use a 'simpler' 35mm adapter which doesn't flop the image, the image will arrived upsidedown in your camera. Flopping the image with mirrors and lenses in an adapter will 'cost' you light. Without that part, you'll have more light, but you had to flop the image in post.
By flopping it electronicly in camera you will save both light and render/conversion time.
(A 35mm-adapter enables you to use 35mm (photography)lenses)
And offcourse you can flip/flop images if you want to, just because it is possible ;-)
Brainstormnavigator searching for the hole in the sky.....
Audiovisual Designer (NL) - http://www.brokxmedia.nl
Walter Brokx is offline   Reply With Quote
Old August 23rd, 2010, 01:18 PM   #6
Sponsor: Westside AV
Flipping is also used in some 3D rigs where you need to mount one camera upside down (the left one) to get them next to each other at the right distance. This means you don't have to do it in post.
Old August 23rd, 2010, 01:41 PM   #7
Olof is right: I totally forgot about the stereoscopic mirrorrig...
Old August 23rd, 2010, 02:11 PM   #8
Walter and Olof, thank you for your perfect explanation. That was just a pure language barrier, with this term I was initialy caught in the world of electronic circuits and logic components…
http://en.wikipedia.org/wiki/Flip-flop_(electronics)
I had never heard of flip-flops before in terms of inverting the image. So now I know that this word belongs into the same chamber where English natives keep their “seesaws” too ;-).
Old August 25th, 2010, 05:11 AM   #9
Images: 10
On the subject of 35mm adapters, what the current best option for EX's? Letus Ultimate?
The M3 still hasn't been released has it?
Cheers, Duncan.
Duncan Craig is offline   Reply
