Best way to delete files from Sony SXS Mem cards
I would appreciated if anyone of you tell me the best way of deleting clips/files from Sony SXS Mem cards??
Thx Pushpa
Pushpa-Brisbane-Australia Dell Dimension 8400;2.8GHz, 2GB RAM, Win XP with SP3, 1TB HDD;Sony PMW EX1 VideoCamera |
After exporting mxf to my HDD, I have simply been using ClipBrowser's "delete" function for that, but frankly, I share your doubts.
Interestingly, Convergent Design stress it very much that no deletion/formatting be done on the computer; instead the nanoFlash format should only be used on the CF cards. Their point being that this way, fragmentation of media is avoided, and hence performance is increased. I guess Sony should advice their SxS users which is the best method, in the long run. PS. There are at least two aspects to consider here: - the performance and endurance/longevity of the media - the workflow strategy.
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive |
What's wrong with just reformatting the cards in the camera?
#5 |
i use SD cards for scene files and keep the SxS cards purely for video storage.
My preferred workflow is to back up each card as soon as possible to a NexTo DI and a portable USB so I have 2 verified copies of the footage before reformatting in the camera - works for me. |
#6 |
Since all solid state memory has some sort of a limited life in read/write cycles - some a lot longer than other designs, I wonder how reformatting a card compares to just deleting clips? My understanding is that in solid state drives the data is actually erased by setting the bits to zero as compared to a spinning disc hard drive where only the reference to the space in erased in the "index" marking that space as useable, but the actual data on the disc remains.
I always reformat my cards before I use them since I don't keep camera profiles on them nor do I name my cards. |
#7 |
Ditto. I'm not a seasoned expert, but I've been told that deleting clips through your computer or in-camera either leaves residual data or cannot detect errors that can occasionally pop-up in the solid state memory, which can FUBAR a subsequent shoot. I just take the advice of the pros and reformat after I've sufficiently backed up my files elsewhere.
#8 |
