EX1 focus went out/IS? at DVinfo.net
Old July 19th, 2010, 02:52 PM   #1
At the end of my wedding on saturday my EX1 lost focus. I had to turn off the camera and turn it back on to recover focus. It was fine when I zoomed in but as soon as I zoomed out I lost the focus. Since then its been fine.Also there is a slight horzontal image slide with IS engaged after a movement.If IS is not engaged there is no image shift. I don't recall seeing this before. The camera has 499 hours on the hours meter.
Should I send it in?
Would updating the firmware help?
Is this normal behavior?
Mervin Langley is offline   Reply With Quote
Old July 20th, 2010, 04:19 AM   #2
Back Focus is out - Dont panic Fixable!
I saw this video on a blog just yesterday explaining your problem.
It should fix the focusing issue you have.
Let me know how you get on.
Adjusting Back Focus On An XDCAM EX Camera | CineTechnica
Dave Grant is offline   Reply With Quote
Old July 22nd, 2010, 11:40 AM   #3
Is it necessary to put the camera in 60i mode during the FB procedure? I had a couple rentals on a shoot recently and I tried a few times to set the backfocus properly with a large DSC Fiddlehead chart at 12 feet away (about 3 meters as suggested in the manual) and still couldn't get them tack sharp. I hadn't thought to switch from 24p to 60i.
Tim Dashwood
Old July 24th, 2010, 10:18 PM   #4
I don't see how this has anything to do with back-focus.
Mervin, the same thing happened to me 2 weeks ago. After 10 minutes of use, my zoom and focus stopped working but was fine after rebooting the camera. Since then, everything has been fine. I also started a thread here when it happened, and everyone said to contact Sony to get it serviced. My Abel Cine sales guy said Sony might just replace the lens because others have had a similar problem but their focus/zoom had completely died.
Steve Kalle is offline   Reply
