Import ex files to avid MC4 via AMA?? at DVinfo.net
Old July 17th, 2010, 06:35 AM   #1
Hello,
i have copy 2 cards with 1920x1080 to my local hard disk.
The problem is that AMA is working only if i have insert a SxS card to card reader.
How i can import these files to avid?
And what resolution i have to use?
DNxHD 120 MXF, or XDCAM EX 35 Mbits MXF??
Something that i have in my mind, is to convert all these files with clip browser 2.6 to MXF, and then import them into avid, not with AMA, but with the import function.
Looking forward to your reply
Giannis Pass is offline   Reply With Quote
Old July 19th, 2010, 12:07 AM   #2
Please, i need your help.
Old July 19th, 2010, 12:46 AM   #3
Select File > Link to AMA volume > "Folder" , where "Folder" = the folder just above your BPAV folder on the card.
This will ONLY work if you've copied the exact contents of your card onto your hard drive.
As for how to import it, that is up to you. For quick edits I simply inport the XDCamEX 35. For high end work I import at 10bit DNxHD codecs. For proxy work, I import DNxHD 36.
Old July 19th, 2010, 01:26 AM   #4
Thanks for the reply.
The structure is: Card-BPAV-CLPR and TAKR-and into the clpr are all the clips.
What i have to choose, as folder into MC??
Thanks again
Old July 19th, 2010, 06:07 AM   #5
Thanks again
Click on card.
Perrone Ford is offline   Reply
