Thread Tools
Search this Thread
Libec ZC-9EX zoom controller faulty?
Just received my Libec ZC-9X Zoom Controller for my EX1 camera and am disappointed to find it appears to be faulty. On a zoom in if you don't return it to center it continues to zoom in very slowly. . .zoom creep? If I do a faster zoom in and release it quickly this doesn't happen. Zoom outs are fine. Seems the zoom in is set very fine as you only have to give it the slightest of touches for it to start a creep zoom. On the zoom out you have to turn it at least an eighth of an inch to get it to start. Anybody else have this problem and is there an easy fix(unlikely but you never know:-)? Bought from B & H and as I live in New Zealand not overly eager to return it unless I have to.
Mark |
#2 | |
I found this distributor for New Zealand: Unit 11,83 Wollongong Street Fyshwick A.C.T. 2609 (P.O. Box 250 Curtin A.C.T. 2605)�@Australia TEL:+61 2 6281 5483 FAX:+61 2 6281 0062 Contact:David Cooper sales@gdbint.com.au G.D.B. InternationalAV - Video and Multimedia Specialists Libec-HEIWA SEIKI KOGYO.,LTD. LIBEC products are available through local distributors. We currently have sales networks in more than 60 countries, and the number is expanding every year. These distributors also provide customer service. Customers can obtain prompt service, including repairs and parts replacement. There is also a company Contact page here: https://gt203.secure.ne.jp/~gt203072...t/contact.html John |
I know what the problem is.
Mark, i had exactly the same problem.
Your Libec controller is fine, your EX1 is fine, they may not be compatible. My EX1 worked perfeclty with my Libec controller until my lens went faulty, i had a new lens fitted by Sony service, then my Libec controller did exactly the same as what yours does, the problem was that the new lens looks exactly like my old lens but it's different on the inside,(words direct from the Sony techinicians mouth), with the new lens and the Libec controller i needed the newest (at the time) firmware, Sony had notes on how the not newest firmware and the newest lens were not compatible with the Libec controller, once they upgraded my firmwar to V1.14 all was well, since then however there's newer firmware which i installed myself. See my old post from ages ago http://www.dvinfo.net/forum/sony-xdc...end-feb-2.html What firmware do you have ? Paul.
Round 2 GH5,FZ2000 Last edited by Paul Kellett; July 11th, 2010 at 10:49 AM. Reason: .. |
One thing to check out before you send it back. The center position of the zoom rocker is "zero". If you plug in the zoom controller into the camera with the rocker off of the "center mark". It will continue to creep zoom. Check to see if there is slop in the zoom rocker with it sitting at zero. If there is a bunch of play that could be it. As well, the rocker post could have been installed off-center, with the post inside the rocker slightly cocked to the left or the right causing your problem. If I were to wager on this, I would say this is the problem.
Not sure if this is clear but if it is and you are feeling adventurous, you may be able to get it sorted yourself. EDIT: To see if Paul's theory is correct, you could take your remote to a local Sony pro dealer and try the remote on another camera. |
#5 | |
That could be the problem. It was one of the original EX1's but about 10 months ago the lens went faulty and Sony replaced it. They upgraded the firmware at that stage but it hasn't been updated to the firmware that came out this year. . . (I am on V1.11_0531)
I guess the next step would be to upgrade the firmware and see what happens. . . Mark Quote:
#6 | |
I tried what you suggested and checked that it was in the center but its still playing up. It doesn't appear to be sloppy in the mechanism but the zoom in side is exceptionally sensitive with even the slightest touch setting off a creep zoom. If it isn't what Paul suspects(the firmware) then my second guess would have to be that the rocker has been installed off center, and that would mean returning it.
Mark Quote:
#7 |
Update:
I installed the latest firmware(1.20) and. . . . . . .the controller is still creeping on zoom in :-(
So back to its distributor it goes. Thanks to all who offered help. Mark |
#8 |
If there is one make sure that the inline plug is properly connected. Make sure it's all the way in. One of my Libec controllers started zooming in as soon as it was connected to the camera and I traced the problem to that inline plug.
- Don |
#9 |
Sponsor: TapeWorks Texas
Also, there are 2 versions of the ZC9EX, the older version has been phased out about 6 - 8 months ago. You may have been sold one of the last remaining older versions. There is nothing
Ask you Libec distributer if they sold you an older model or one of the newer models and if they would be willing to swap out for the newer model. I bet this is what happened! |
#10 |
My Libec is about 2 years old.
Paul.
Round 2 GH5,FZ2000 |
#11 |
Final Update
I had to send the unit back to Libec in Japan. It was back here in just under a fortnight. They repaired it rather than replacing it.
The fault was as they put it "Seems it was the problem of connection between the control bar and cable". Working OK now other than it seems pretty hard to do a smooth zoom in. . .it seems to jerk at the start of the zoom however softly I touch it. Mark |
