EX-1: Lens Info not showing up at DVinfo.net
Old June 30th, 2010, 02:31 PM   #1
I was piddling around with the menu settings with the EX-1 and all of a sudden i can't get Lens Info to display. all i get are STBY and REC. I turned of/on, took out battery. The only thing i did different in the menu was CLIP>UPDATE>MEDIA>A, whatever that is.
Whenever i push the Lens Info button i get nothing.
David Soriano is offline   Reply With Quote
Old July 1st, 2010, 12:58 AM   #2
David,
Lens info is just one of the many elements of the display. You can toggle Lens info on/off, but to see it you need to have the general display activated - this is done with one of the buttons under the handle. You must have knocked it accidentally.
Old July 1st, 2010, 08:04 AM   #3
no dice
got it...thanks!!!
