EX 3 Front Shoe Mount at DVinfo.net
Old June 17th, 2010, 03:19 PM   #1
Hello everyone.
The Front Shoe mount on my EX3 is a little loose so I am afraid that it will break or fall out.
Did this happen to anyone? If it did how can I tighten it?
Leo Morita is offline   Reply With Quote
Old June 17th, 2010, 03:48 PM   #2
Mods please delete this thread... I found out how to tighten it....
Sorry
Old June 18th, 2010, 07:49 AM   #3
Why delete it...
Explain how you did it so others will know in the future.
Gary
http://www.mlotv.com
Gary Brun is offline   Reply With Quote
Old June 19th, 2010, 07:47 AM   #4
I had the same problem. All you do is unclip the silver metal cover (I had to use a small screw driver to gently pop it off) and tighten the screws. However my screws seem to be slowly eating into the plate itself from the twisting action. I hope it doesn't loosen again, not sure how many times I could re-tighten it.
Josh
Cameraman | www.josh-white.co.uk
Josh White is offline   Reply With Quote
Old June 19th, 2010, 11:51 AM   #5
Sponsor: Westside AV
You may consider pulling the screws out and applying a little blue locktite to the threads, only a little and don't use the red.
Old June 20th, 2010, 04:32 AM   #6
Olof, any plans for a front shoe mount replacement? Even with tightened screws, it really can not carry a microphone in a (Sennheiser) shockmount for more than a dozen mobile sessions.
EDIT: My EX1 gets most of its use in hand-held operation. I realize that I am over-burdening the shoe mount. I run with two microphones: AT shotgun and Blue Dragonfly large diaphragm. The heavier Blue is on the hot shoe while the lighter AT is on a Lightwave shockmount that has replaced the stock EX1 shotgun mount. At this point, I need to retighten before every session.
Gints Klimanis is offline   Reply With Quote
Old June 20th, 2010, 06:47 AM   #7
2 years with a Rode SM3 mount carrying a Sony ECM678 on my EX3, hand held and Steadicam. Re-tightened once, and it's solid as new. That's a very large number of uses beyond a dozen...
www.davidwilliams.com.au
David C. Williams is offline   Reply With Quote
Old June 21st, 2010, 05:42 AM   #8
Gints, it would be easy to make a mic holder that attaches to my "wing". Contact me if you are interested. I will quote you for a prototype. I could make it so it holds a light as well.
Old June 21st, 2010, 09:40 AM   #9
If you make a prototype I would be interested in seeing some pics of it -- might be interested.
Really happy with the "left-eye" dominant rig you made for me.
Tom Robertson is offline   Reply With Quote
Old June 21st, 2010, 05:40 PM   #10
Originally Posted by David C. Williams View Post
Re-tightened once, and it's solid as new...
Tightened both of mine down as they get used a lot. Solid as a rock (well maybe not that good). I would caution people when tightening the screws. I wouldn't be surprised if the metal they are screwing into is a "soft" aluminium housing that a plagues a lot of electronic products.
Old June 23rd, 2010, 01:30 PM   #11
I had the same problem with both the front and back shoe mounts getting loose. I put a Sennheiser receiver or Zylight Z90 on the front shoe and either the Sennheiser receiver or my PHU-60K on the back shoe. At one point the back shoe and the shoe attachment on the PHU-60K were so loose that the PHU-60K fell off, giving me a mild heart attack. I figured out how to tighten both and so far they are holding well. I didn't think of putting any lock-tite on the screws at the time, but if it ever loosens again I will.
Alan McInnes
Web and AV Services - Southridge School - www.southridge.bc.ca
Alan McInnes is offline   Reply With Quote
Old June 23rd, 2010, 01:51 PM   #12
My PHU-60K did fall off and snapped the small USB 2 port of the circuit board.
Totally useless and Sony don't do parts for it either.
So I don't know why they call it a Pro Product!!
Money just down the drain.
