Sony PMW-350 Audio Channel Setup? at DVinfo.net
Old June 16th, 2010, 11:11 PM   #1
Since I don't own the camera yet I haven't had a lot of time to work on the setup although I've been searching all over the Internet to learn as much as I can. I'll be shooting with it this Saturday. Sony says this camera can record 4 channels of audio. I've been experimenting with the camera for the last couple of hours. There are only three audio inputs that I can find. Channel 1, Channel 2 and the shotgun mic channel on the front. I can't figure out if the 4th channel would be using the internal Sony wireless system or not. Before actually looking at the camera I thought I could plug in whatever 4 types of inputs I want. That doesn't seem to be the case. Any experience?
Robert McGowan is offline   Reply With Quote
Old June 17th, 2010, 12:06 AM   #2
The front shotgun mic input is 2 channel stereo, 5 pin female. If you want to input 2 sources other than the shotgun, I think you'd have to get an adaptor cable, something like this
Neumann | AC-21 5-Pin XLR Male to 2 3-Pin XLR Female | AC 21
I don't know about phantom power through these, though....
Old June 17th, 2010, 12:48 AM   #3
Warren,
I was hoping I could somehow attach 3 wireless feeds as well as the front shotgun but I don't know if that is possible other than buying Sony's very expensive wireless system not sure if that's possible either). I have an Audio Technica 1800 attached to the back right now. It's a two channel dual diversity receiver so that's how I have two feeds. I'd like to have the ability to capture three. Cheers.
Old June 17th, 2010, 09:14 AM   #4
You can as mentioned by Warren. Get a adapter cable and a different shotgun and your set. Want a nicer solution? You have to buy a slot receiver, but then you pay way more...
Vincent Rozenberg is offline   Reply With Quote
Old June 17th, 2010, 11:27 AM   #5
Originally Posted by Robert McGowan View Post
Warren,
Still can be done with that adaptor cable. Replace the front stereo shotgun with a 3 pin mono XLR. Connect to left channel of adaptor cable. Connect new wireless receiver to right channel of adaptor cable. Keep AT dual connected to rear connectors.
Warren Kawamoto is offline   Reply
