True Uncompressed Anamorphic EX3... yeah at DVinfo.net
Old May 8th, 2010, 09:40 PM   #1
So I have this feature coming up this summer and I was thinking about doing this: Sony EX3 + Canon B4 to EX3 Converter + Canon ACV-235 Anamorphic Lens Converter + Anamorphic Primes + Convergent Design's nanoFlash = EX3 Anamorphic 2.35:1 uncompressed 4:2:2...
Does anyone think this is stupid? Any thoughts or concerns?
How do you convert Anamorphic (unsqueeze) in Final Cut?
Where can I rent a ACV-235 and B4 to EX3 Converter?
Will there me a magnification in focal length since this will effectively convert the 1/2" to 2/3" ?
I really want to try this.
Scott Toler Collins
www.STCinema.com
Scott Collins is offline   Reply With Quote
Old May 8th, 2010, 10:56 PM   #2
Nanoflash doesn't do uncompressed, and never will I think. FlashXDR has that coming I understand. Still, you can't see the difference in uncompressed vs 160Mbit anyway.
The ACV-235 with a B4 to EX might work. Stacking adapters can lead to vignetting and backfocus problems, but if they are designed properly, you should be able to adjust to compensate. I think the 1/2 to 2/3 crop factor is about 1.37. You will probably lose a few stops through the ACV-235 too.
Being a rear anamorphic it probably optically crops the top and bottom, then gives a vertical stretch. Your field of view vs focal length will probably stay roughly the same as 1/2, but when stretched in post it may give an apparent deeper depth of field.
www.davidwilliams.com.au
David C. Williams is offline   Reply With Quote
Old May 8th, 2010, 11:34 PM   #3
I appreciate your thoughts David. I'd love to test this out if I can find a place to rent these adapters.
Scott Toler Collins
www.STCinema.com
Old May 11th, 2010, 07:04 PM   #4
An article about it being used here-
HD Magazine - HD Mag - Qui Es Tu? AnamorphicCanon
No screen shots, not much technical info, and it reads like a paid advert, but they seem happy with the results.
