Ex1 File System at DVinfo.net
Old May 7th, 2010, 11:36 PM   #1
Ex1 File System
Hey all,
So I am noticing that unless you have the BPAV folder, the 2 folders inside that folder and the clips, Adobe CS3 wont read the files....... anyone have any thoughts on this?
It would be ideal to stick all the Mp4 files in a folder and be able to use them.
Silas Barker is offline   Reply With Quote
Old May 8th, 2010, 01:28 AM   #2
I think it is agreed that the BPAV should be kept intact. All the bits and pieces in the BPAV have a function and could be needed in the future.
Bruce Rawlings is offline   Reply With Quote
Old May 8th, 2010, 01:53 AM   #3
Anyway to import more then one clip in to adobe at a time?
Real pain to import multiple clips if you have a few hundred
Old May 9th, 2010, 10:48 PM   #4
You can make a search within the BPAV folder for *MP4, then copy all files to a separate folder for editing...
Thank you.
Ilya Spektor is offline   Reply With Quote
Old May 9th, 2010, 10:51 PM   #5
All the BPAV and files should be kept intact to work correctly.
Old May 10th, 2010, 01:12 AM   #6
Just import the complete BPAV folder. Sure there will be an error message then, but you don't have to do a search for *mp4 files. Click just OK and you'll find all clips within the imported BPAV folder now.
Swen Goebbels is offline   Reply
