motion blur on EX1r
Man, I love my new ex1r. The pictures are stunning. But I'm getting unacceptable motion blur and jerkiness every time I do so much as a simple pan! I'm automatically attributing it to operator error but I'm hoping someone who has had the same problem will come to my rescue. I've been shooting primarily in 1/50 shutter speed and shooting routine stuff -- not fast-motion sports by any stretch. I've been shooting 1920 X 1080p using various picture profiles I've stumbled across here and other professional sites. Plu leeze help!
Vortex Media
Hi Charles,
There can be several reasons why you’re getting unwanted motion blur, but you haven’t given enough information for anyone to really pinpoint the cause. You say that you’re shooting 1920x1080, but that doesn’t provide any clues. That’s just a frame size. It’s the frame-rate that matters most. Are you shooting 24P, 30P, 25P, 60i, or 50i? The recommended shutter speed will vary depending on your frame rate. 24P: 1/48 30P: 1/60 25P: 1/50 60i: 1/30 50i: 1/50 Notice that the recommended shutter speed is always ½ of the frame rate. You can vary a little bit from those numbers, but if the shutter speed is too slow you’ll get excessive motion blur and if it is too fast you’ll get strobing. On the EX1, EX1R, and EX3 I shoot almost exclusively 1080/30P @ 1/60th and I have never had a problem with unwanted motion blur. Keep in mind that some motion blur is absolutely necessary if you want your video to look good. Here’s a few random thoughts that might help you solve your problem: 1) Is the shutter switch on the front of the camera (under the lens) turned on? If the switch is not turned on, then the shutter speed will be too slow. 2) Progressive looks different than interlaced (that’s why we like it!!) and it takes some people a little time to get used to it. 3) If you’ve spent too long shooting at shutter speeds that are too fast, you’ll have to adjust your eyes to the look of using 1/60 or 1/50. 4) Are you judging the motion blur by what you see on your viewfinder? Don’t. 5) Are you judging the motion blur by what you see on your computer monitor? Don’t. 6) You can only tell what things really look like if you use a proper HD video monitor. 7) Changing your Picture Profile settings won’t make any difference with motion blur so don’t waste your time going down that path. One or more of the things I’ve mentioned must be the culprit because the camera handles motion beautifully. I guarantee it. Check your settings, make sure you’re judging the video on a decent monitor, and I’m sure you’ll figure it out. (My vote is that you don't have the shutter switch turned on.)
Vortex Media http://www.vortexmedia.com/ Sony FS7, F55, and XDCAM training videos, field guides, and other production tools |
Turn the detail down
Colin |
I bet you come from a non-progressive background and you are just shocked by the natural jerkiness of shooting 24p or 25p, there's probably nothing wrong with your camera or your settings... maybe you could upload a sample for us to judge?
#5 |
Are you judging your footage from what you see with XDCam Transfer Tool? Don´t.
#6 |
How does your footage look in 720p60 ? Also, are you using the optical image stabilizer ?
Host a sample somewhere. |
#7 |
I am a bit compelled to argue with folk on this one.
All of the small cameras and some larger ones are marvellous contrivances which do amazing things and record to small media packages. However nothing comes from nothing. There is no free lunch. With compression to enable a lot of visual information to be jampacked into recording media, something has to give. Whole motion across the entirity of the image is a very severe test. A compression scheme which takes a keyframe every fifteen frames or whatever the builder has chosen to use, obviously cannot create an entirely new image for each frame. Fortunately, movement also tricks our eyes with the same artifact, motion blur and the clever little guys in R&D allow the camera to toss away some resolution in favour of a smooth frame rate and mostly with success, hide it in the normal motion vision defects of our own natural eyesight. So. Point a modern consumer/prosumer video camera mounted on a fixed tripod at a siemens chart fully framed. Look at the pattern. Sharp isn't it. Move the camera ever so slightly and watch what happens to the centre of the pattern. The centre blurs out wider momentarily as the the system makes decisions to preserve smooth motion, then sharpens as the camera settles. The cameras do what they do, mostly brilliantly. It is up to us to learn to live within their means, a craft film cameramen have already evolved to a high science over nearly a century. Last edited by Bob Hart; April 27th, 2010 at 05:28 PM. Reason: error |
#8 |
Doug,
I'm curious as to why you'd suggest shooting 60i at 1/30 rather than 1/60 or 1/120 depending on lighting conditions? Thanks, Garrett |
#9 |
Vortex Media
Oops!!! That was a typo. Sorry. I'd edit it if I could . . . but there's no "edit" button on that post anymore.
It should be 1/60 for 60i. I'm sorry for any confusion that may have caused.
#10 |
Thank you Doug... We love ya!
