How to view EX .movs from FCP, on a PC at DVinfo.net
Old April 15th, 2010, 04:48 AM   #1
I have created QT .movs from xdcam ex clips, by importing them into FCP using Log+Transfer. Do clients need anything on their PC other than QuickTime, to view these movs?
Mark Slocombe, CreationVideo
http://www.creationvideo.com
Mark Slocombe is offline   Reply With Quote
Old April 15th, 2010, 05:29 AM   #2
CalibratedSoftware XDCAM EX .MOV plugin for non FCP systems (Mac and Windows versions). It's about $80.
You should really give them the source BPAV and ClipBrowser which costs nothing.
Old April 15th, 2010, 06:06 AM   #3
Or VLC (also free), which plays much better full-screen than the CB, and can scan all contents of the BPAV structure for uninterrupted playback of all clips.
Old April 15th, 2010, 06:07 AM   #4
Cheers Craig - wanted to avoid needing them to download clipbrowser and was advised that QT was fine for them - do you mean xdcam movs will NOT work on a PC without the Calibrated software?
Old April 15th, 2010, 06:10 AM   #5
Will VLC play the QT mov I made, on PC?
Old April 15th, 2010, 07:40 AM   #6
Hi Craig - this worked fine for my client, and there is a free demo mode fyi. Thanks for your help.
Old April 15th, 2010, 10:49 AM   #7
I have never gotten VLC to play my .mov's. I also use the Calibrated Q
....ahhh, are you saying VLC for the BPAV's??
Annen James is offline   Reply With Quote
Old April 15th, 2010, 11:55 AM   #8
I didn't mean using VLC to play movs. I seconded Craig in his opinion that the full BPAV should always be handed over, and all mp4's inside it can be played back after directing VLC to the BPAV root folder.
Old April 15th, 2010, 11:57 AM   #9
VLC will play the .mp4 files inside the BPAV\CLPR folder. Once you convert the files in clipbrowser, they are good for either Mac (.MOV) or PC (MXF). The two do not cross over without 3rd party software.
Best just to give someone the BPAV folders and let them do what they need.
Perrone Ford is offline   Reply
