Quick test with new Schneider Optics Platinum IR 1/2 stop filter on the PMW-EX1 - Page 2 at DVinfo.net
Old May 3rd, 2010, 01:17 PM   #16
Sponsor: Schneider Optics
Originally Posted by Charles Newcomb View Post
Also, can it be piggybacked with a thin UV filter w/o vignetting?
Charles,
You could use a thin UV filter but I wonder why you would. The only reason might be protection of the filter or if you were shooting at very high altitude but otherwise the extra air-to-glass surface that the UV provides would be more of a downside and than positive.
The vignetting issue on 486 filters does not come from the UV filtration but rather the IR filtration where you have 30+ layers of coatings that show in the image at wide angles. The Platinum Series IRND and Platinum Series 1/2 Stop are absorbtive and therefore do not have any vignetting issues.
Ryan Avery
Schneider Optics
Ryan Avery is offline   Reply With Quote
Old May 3rd, 2010, 01:58 PM   #17
Hello, Ryan:
Thanks for your response.
I live at 8,000' elevation and I regularly shoot at elevations from 7,000' to 12,000'. UV is an issue up here.
Aside from that I keep the UV filter on as protection from scratches and such.
I was going to buy an ND filter that is also a UV filter (sometimes I need just a tad more ND than one can crank in on the camera) before you announced this new one.
EDIT: Never mind. I decided to get a matte box and use the 4x5.65 filter instead of the screw-in one. Thanks.
Charles Newcomb is offline   Reply With Quote
Old May 4th, 2010, 10:33 AM   #18
Charles,
I got your edit but I thought I would add one little known note.
Schneider True-Pols and B+W Polarizers filter out all UV light below 410nm which is what a normal UV filter does and what everything except "aircraft grade" UVs (UV417, etc) filter out. So there is no need for additional UV filtration when using a Polarizer.
Polarizers also loose about 1.7 to 2.1 stops depending on the angle of incidence of light so that could be a useable solution short of ND and a UV.
Ryan Avery
Schneider Optics
